02-23-2017 03:02 AM
187 ... 678
tools
  1. Raizz's Avatar
    I think I Got it Finally.
    Recovering Data is not the solution Not even Formatting your SD card.
    I have the same problem after some days it doesn't load some Apps in Android when i check it in the settings it shows "DAMAGED SD CARD"
    I tried to connect with SD CARD Adapter slot in my Laptop but still couldn't detect and it asked to Format it.
    I tried to fix it with "CHKDSK" utility but couldn't do it through windows.
    But could do it with command prompt.
    Not if you have the same problem follow.....
    connect your SD card to computer.
    open command prompt.
    How ? .......
    open run from start button
    then type "cmd"
    now type
    chkdsk /X /F <SD card drive letter>:
    If its K drive then
    chkdsk /X /F K:
    It will check your card and will repair it.
    Have patience it will take around 10 min.
    when it is done windows will detect your card evn your android phone.
    Have a nice day......
    This worked perfectly. Scanning completed in just 5 seconds too
    Thanks a lot mate, you saved a LOT of my stuff
    07-13-2016 12:59 PM
  2. jelmed's Avatar
    It looks like a corrupted SD card.Check here for symptoms if the SD card is damaged or corrupted
    Symptoms Of A Damaged or Corrupted Memory Card!
    11-04-2016 05:46 AM
  3. AmayaMoon's Avatar
    hey i kept trying to fix my damaged sd card but nothing would work
    until i finally tried something. all you need a another android phone and
    your damaged sd card. and all you do is plug in the sd card in the other phone
    it should say its damaged or something and all you do is touch it in the notifications
    and it will as you to format it so do it and after its done put it back on your
    original phone]
    and there you have a working sd card
    took me a while to figure this out and i can gaurantee it will work on yours.
    My phone started overheating first and I have no other phone so what should I do?
    11-18-2016 08:31 PM
  4. romkristoff's Avatar
    I tried this one but nothing happens. When i try to mount it, it keeps saying damage sd card. My sd card works fine in different device and on pc.
    11-28-2016 04:10 AM
  5. labib14's Avatar
    chkdsk is not working for me it didnt help it says accecs i denied plsss helpppppppppppppp always save all files to my sd card help me
    12-06-2016 05:50 AM
  6. anon(632115)'s Avatar
    The sd card needs to be in a card reader, not the phone
    12-06-2016 06:18 AM
  7. Mamero Tan's Avatar
    How ? .......
    then type "cmd"
    now type
    If its K drive then
    chkdsk /X /F K:
    I know its an old post, but really, thank you so much
    01-26-2017 06:23 AM
  8. Anamil Acevedo's Avatar
    Oh,,,, hi ,, pls help me how to fix my sd card damage it won't mount,,iphone7
    01-27-2017 08:18 AM
  9. ismailmiller's Avatar
    I've tried that several time yet my device continues to say "DAMAGED SD CARD" , what now?
    02-15-2017 12:00 PM
  10. KGB12's Avatar
    can u help me.........my phone says that my sd card is damaged, so i tried to format it but it didn't happen.so i put it on pc to try to format it but it says that windows cant format it..but the file is there but it cant be deleted...
    02-23-2017 02:54 AM
  11. KGB12's Avatar
    it didn't work on me
    02-23-2017 02:56 AM
  12. KGB12's Avatar
    02-23-2017 03:02 AM
187 ... 678
  1. Replies: 55
    Last Post: 08-31-2016, 03:51 PM
  2. SD card damged on mount with apps2sd
    By redbeardtheweird in forum HTC Hero
    Last Post: 10-11-2014, 04:47 AM
  3. Damaged SD card error?
    By bbasiaga in forum Barnes & Noble Nook Color
    Last Post: 09-01-2013, 12:41 AM
  4. HELP! "Damaged External SD card" Error
    By tarichar in forum Verizon Fascinate
    Last Post: 06-01-2011, 02:27 PM
  5. G1, sd cards, and pc mounting
    By hououtate in forum T-Mobile G1
    Last Post: 09-28-2009, 03:12 AM
