Somdk
Re: Damaged Sd card Error / Wont Mount - Fix??
I will not say it myself, but CHKDSK checks for errors on disks, as the name suggests. You read more about it on Google. Also in dos/command key in HELP CHKDSK to know more about its functions, i think thats the proper code. Also have you tried Recuva, it only saved me when my memory card went currpt.
yes it is and i use some software recovering stuff to get some files luckily i recovered some but im still trying to fix it.it is visible on the my computer and yes CHKDSK didnt read it cause its says its unavailable for RAW drives.btw is CHKDSK some sort of disk protocol or something like the ones u used for hidden drive files?
