1. HeartOfSecrets's Avatar
    I will have my Samsung Driod Charge for a year in March and well NOW its messing up! It was either last night or the night before it would kinda of recongize the charger but then not. Everytime id move it would stop charging and i tried on both my wall charger and car charger and I rarely ever used my car charger!
    Then when it does charge it is very slow. I charged it at around 4PM and i went to sleep and its now 7:40 and its at 28% as we speak.
    So I was wondering if you ever had any similar issues with this product and if so, what was your solution? Need help with it! Thanks!
    10-23-2012 07:41 PM
  2. t_kopta's Avatar
    My year is up in November and I saw issues arise as it nears. My suggestion is that you keep on tech support until they resolve the issue with replacements. After a while, and if it still doesn't work well, then maybe they could put you on a new device. Good luck. My Charge is crappy and slower than eva!!!!
    Sent from my SCH-I510 using Android Central Forums
    10-24-2012 06:31 AM
  3. kraisydave's Avatar
    Batteries do go bad. It could be the power connection, but likely the battery. Replacements are cheap on Amazon. If you get a knock off, know that you cannot use these to root. It must be an original battery.
    Dave
    11-01-2012 12:46 AM
  1. Question regarding Picasa albums in my gallery
    By EvilMonkey in forum Samsung Galaxy S3
    Last Post: 07-13-2012, 01:13 PM
  2. Replies: 28
    Last Post: 06-13-2012, 02:36 PM
  3. Calender Question for my Charge
    By mrcraigp in forum Verizon Droid Charge
    Last Post: 10-01-2011, 09:29 PM
  4. Replies: 3
    Last Post: 05-02-2011, 12:03 AM
  5. questions regarding Bump Charging
    By DougFNJ in forum Verizon Droid Incredible
    Last Post: 07-14-2010, 08:54 PM
