DEAL OF THE DAY: Save 42% on the iBOLT Vehicle Charging Dock for Samsung Galaxy S3!
Results 1 to 2 of 2
Like Tree1Likes
  • 1 Post By starbuckk
    Default Should I get a charge as a replacement?
    Verizon is offering me a Charge or an LG Revolution as a replacement for my Thunderbolt crap. Is the charge good? Does it hold data connection, battery, etc? Thanks.
  2. #2
    Default Re: Should I get a charge as a replacement?
    I picked the charge over the other choices of the time including the Thunderbolt because of the superior screen. I haven't regretted it.
    Battery isn't great but no smartphone is. Juice defender helps.
    Data connection seems stable enough. I have trouble around my home but did with my pre as well.
    It has a little less ram than some others but unless you are a total app junkie that shouldn't get in your way. High quality screen trumped ram for me.
    Sent from my SCH-I510 using Tapatalk 2
    GKWANNABE likes this.
  1. Replies: 21
    Last Post: 10-10-2011, 10:02 PM
  2. Getting a X2 as a replacement from Verizon. ROMS?
    By LVracerGT in forum Motorola X Rooting, ROMs, and Hacks
    Last Post: 08-11-2011, 12:01 AM
  3. should i get my phone replaced?
    By alextrox69 in forum HTC EVO 4G
    Last Post: 08-19-2010, 11:19 AM
  4. Should I get my Incredible replaced?
    By wavechaser in forum Verizon Droid Incredible
    Last Post: 07-23-2010, 06:39 PM
  5. Should I get an Android or not??
    By davidg4781 in forum The Android Central Lounge
    Last Post: 12-20-2009, 10:22 AM
