Results 1 to 11 of 11
- 05-05-2011, 09:17 PM
Thread Author #1
Samsung Charge owners
i have a few questions for u.
1) Is there a way to cancel the vibration of every button pressed?
2) I cant sync my yahoo. My droid X let me however on the charge i had to DL a app
3) Besides diff launchers is there a way to change the messaging dock app? I loved my handcent (well besides when i had to delete long txt convo) app but its kinda stupid to have a handcent app plus a messaging app at the bottom of the phone.
Thx for info guys - 05-05-2011, 09:25 PM #2
Yes it is haptic feedback under sound options. As for the keyboard that would be the same settings under whatever keyboard you are using.
I don't use yahoo, you probably just need to look up the server settings and ports and manually put them in.
If you open the app drawer and hit the cog in the top left corner it puts it in edit mode and lets you rearrange apps including the ones on the dock.
One cool thing about the stock messaging app is the puzzle lock screen. When you have a text you can drag the top puzzle piece to take you straight to the text. Luckily samsung has a good looking stock messaging app. - 05-05-2011, 09:35 PM
Thread Author #3
- 05-05-2011, 09:43 PM #4
- 05-05-2011, 09:45 PM
Thread Author #5
- 05-05-2011, 09:56 PM #6
- 05-05-2011, 09:58 PM
Thread Author #7
- 05-05-2011, 10:03 PM #8
- 05-05-2011, 10:06 PM
Thread Author #9
- 05-05-2011, 10:15 PM #10
- 05-05-2011, 10:19 PM #11
Reply
