nope thats kinda sucks but im only using it when i know ill be away from home awhile and heavy using it in the process like stuntin on my friends iphones and stuff
Its not true. I had a Thunderbolt and now own a Charge and its not even close, the Charge has way better battery life.
Does the extended battery fit in the desktop cradle to charge or do you have to charge the battery via phone?
Results: No diff...still sucked but was cool to have a 2nd battery. (Samsungs Y-cable extra battery w charger was awesome). Swapped for the Thunderbolt...In my case for whatever reason the Thunderbolt lasted all day long (7:30-midnight, still had juice but went ahead and charged it). All of this was on 3G btw, except wi-fi in the evening. Obviously when 4G came a few days later the battery was drained faster but I got my "testing" done b4 that. Also, the HTC was not buggy and laggy like the Samsung. I am much happier with the Thunderbolt in every way. I know this is much different than most ppl's exp. with Charge vs Thunderbolt battery life but wanted to provide the results of the exp. I had anyway.After all my research, I am extremely disappointed in the battery life of the Droid Charge. It seems to last the same amount of time as my EVO with a worn out 1 yr old battery. Not kidding. When I saw that my phone said it was the display that was using all the juice I turned it down to one notch above lowest setting. The display was using much less but it still only added around 2 hours uptime. I have yet to make it through a day of work without having to charge it so that it doesn't die before I can get home to charge it. Yes I've got all the stuff tweaked to limit power usage. I ordered a new battery to see if somehow I got a bad battery.
I run a rooted Humble 1.4 rom and get great battery life. I leave all radios on and sync every 2 hours. I have 3 emails pushed constantly & have medium web/text/phone usage. I leave the display at 60% and my original battery always last all day and usually has 20-30% left at night when I plug it in.
I dont know what the problem is??? :-\
