This is a long thread because I have a lot of detail, so bare with me!
I got my phone at Walmart on saturday morning of launch and the battery was 100% DEAD upon purchase! Wouldn't even power up. they had to plug it in and charge it just to activate it for me. I had enough juice to make it out to the car and put it on the car charger for the 15 min ride home, and then charged it on/off over the course of the day until that night when it finally had time to go to 100%
Ever since my Droid1 phone, my usage is "average" and includes Facebook 3-4 times per day, texting, constant Gchat sessions, approx 10 min of gaming, light web browsing, a lot of audio streaming/playback, some youtube, photos and gallery use, sync and use of 3 gmail accounts, and Google latitue (always on)
I always keep my Bluetooth, Wifi, and GPS on at all times on my phones
I never had great success with my battery on the Charge since I bought it several days ago. I live in a 3G area and work in a 4G area.
On 3G network my battery would drain at a rate of 10% per hour giving me 10 hours or less of use
On 4G network my battery would drain at a rate of 20% per hour giving me 5 hours or less of use
I tried everything on the phone to fix the battery issue. I ran Advanced task killer (which had helped my battery life on other phones), installed JuiceDefender, shut off Wifi, Bluetooth, and GPS. removed all widgets and turned screen brightness down to manual with the lowest level. With the phone unused/untouched for an hour, it still continued to drain at the same rates listed above.
I went to Verizon and had the battery replaced. This yielded the same drain times.
I followed the forum on how to "condition your battery". No luck Same drain.
I was ready to return the phone and try another one, but decided first to do a full factory reset, keep all apps, services, widgets, etc. OFF and see how the phone did. If battery was better I would slowly add items back and find the drain. If the battery still drained fast, i was going to return the phone for a new one and try again.
I did the factory reset, and only configured one of the gmail accounts. I removed all widgets, turned screen auto bright off and set it to the dimmest level, turned off GPS, Bluetooth, and Wifi. I let all of the apps reinstall from the market, but made sure none of them were configured to pull any data in any way. I also removed Advnaced Task Killer and NoLED after they were restored.
My phone was doing pretty well! I was only draining about 3% per hour on 3G!! MUCH BETTER than the prior 10% per hour! I put the phone on the charger and went to bed for the night. The following is my experience today:
Conclusion:
I got a full 14 hours of battery life today while using in 4G area! So much better than the prior 5 Hours!!
Factory reset did the trick. I have yet to set up google Latitude, weatherbug, Advanced Task Killer, or NoLED. These are the last items on the list. I now believe that one of these is the issue. Despite great success in the past with ATK, it might have been my root cuase of the drain.
I will continue testing tomorrow and thru the weekend and post any additional info.
- 6:00am I unplug the phone with 100% charge
- 8:00am I start off on my way to work and do a couple of phone calls, some youtube streaming, and checking e-mail
- 9:00am I am at work now (4G area) and with three hours off the charger I am around 87% battery! I set up my other Gmail accounts and start using Gchat and text messaging
- 11:00am I am now seeing an average drain of 5% per hour on 4G. Still not bad! battery is at 75%
- 11:30am I turn on GPS, Bluetooth, and WiFi
- 1:30pm I am around 67% battery Still only a 5% drain and doing well! I turn on auto screen brighness
- 4:00pm I am now around 40% battery after 10 hours of use Apparently the LCD brightness has a slightly bigger drain. I enable all my widgets
- 5:00pm I am leaving work. Battery is at 32% I make several phone calls on the way home and switch from 4G to 3G with no issues in transit. I text and e-mail
- 6:30pm I arrive home and I have 23% battery left
- 7:00pm I turn on Facebook app and log in. I forgot to disable polling so it pulls some notifications for a bit while I am using it. I use some heavy internet browsing and make some phone calls. I am now at 17% battery left
- 8:15pm I am now shopping for food and using an app for my food list. I am now at 3% battery life after making a quick call and using my device a lot for my food list.
- 8:20pm I am back in the car and plug the phone with with just 2% left after 14 hours of use!
Conclusion:
