Results 1 to 10 of 10
- 05-22-2011, 03:39 PM
Thread Author #1
battery life goes from bad to worse thanks to vzw
I like many of the other posters have had a problem with battery life getting sometimes less than 4 hours on a full charge so today i decided i had to try somthing different. i went to the verizon store to try and swap out the battery or the phone for that matter. The tech guy proceded to tell me what was happening to me was "normal". I knew this was not true after hearing the countless storys online that had accounts of people recieveing well over 12 hours of battery life. They tech guys proceded to install Advanced task killer and some ap called phone info. Now my battery is even worse. I called 611 and the lady told me they had to "troubleshoot" the problem before they could do any swapping. Has anyone had any problems like this? They lady on the phone was actually very helpful and said i still had my 14 day worry free date but i thought it was just appauling that the verizon guy went ahead and downloaded thses aps on my phone
- 05-22-2011, 03:48 PM #2
ATK with autokill will only kill your battery, and can cause force close and other issues.
Please see this thread for information on how to improve battery life. It is listed as a Fascinate thread, but applies to all Android phones, except post 2 on clearing bat stats..
http://forum.androidcentral.com/veri...tery-life.html"Give it time. You will be assimilated, resistance is futile. You are only here to serve the green R2D2. posted by HKM"
If someone helps you find an answer, please Thank them with the button in their post.
- 05-22-2011, 03:49 PM #3
- 05-22-2011, 03:53 PM
Thread Author #4
- 05-22-2011, 04:30 PM #5
to be honest ATK is a 3d party app that Verizon does not support and will not support and this rep really has no idea on its effects. I have tested its effects and i know that ATK will kill the phone and so will Lookout i would remove it as the Linix OS does not need a task killer. its not like a windows device. this should inmprove your performance.
and and part of the troubleshooting is removeing all 3rd party applications to see if one of them caused the issue. - 05-22-2011, 05:00 PM #6
- 05-22-2011, 09:05 PM #7
- 05-22-2011, 10:28 PM #8
- 05-22-2011, 10:40 PM #9
the 4g outages yesterday (?) may have had an impact.
- 05-23-2011, 08:03 AM #10
Apparently none of you saw this thread?
http://forum.androidcentral.com/sams...ain-issue.html
Reply
