Results 1 to 22 of 22
    drmahou's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Question Connect connect to computer!
    Hey guys,
    So I'll admit I just joined hoping to find some answers/help as to the issue with my phone.
    I just purchased the Droid Charge 3 days ago and today I attempted to connect it to my computer. I pull down the notification tab upon connecting the phone to my computer and turn on USB storage but my computer comes up with a box asking me to install drivers for the device.
    I have no idea what to do, I just want to be able to access my phone to put my music on it, most likely using doubleTwist.
    Can somebody please help?
  2. #2
    AndroidXTC's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    None
    Default
    What operating system are you using? Mine automatically installed the drivers when I plugged it to the USB port. I'm using Windows 7.
  3. #3
    Farabomb's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    HumbleComb 1.5/PPJ OC
    Default
    No issues with Win 7 or Apple Snow Leopard. I will say it takes it's sweet time to mount.
    drmahou's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Windows Vista...><
  5. #5
    AndroidXTC's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    None
    Default
    Quote Originally Posted by drmahou View Post
    Windows Vista...><
    It should load the same as Win7 but Vista can be wonky at times.
    drmahou's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Well, it doesn't seem to be doing so. My computer keeps asking me to install drivers. What should I do? restart my computer and see if that works?
  7. #7
    Ghetto_Cowgirl's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Try these, just the USB drivers file, not the others:
    Android Charge Files
  8. Thread Author  Thread Author    #8
    drmahou's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by Ghetto_Cowgirl View Post
    How can i be sure that what's in that file is safe... Im gonna need more of an explanation and/or something that isn't as sketchy
  9. #9
    DroidXcon's Avatar
    Posts
    Global Posts
    11,645 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock for now
    Default
    Its reliable I posted it on my thread I wouldn't do that if it wasn't
    Sent from my SCH-I510 using Tapatalk
  10. Thread Author  Thread Author    #10
    drmahou's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by DroidXcon View Post
    okay. Ill take your word. So i just download and install the usb driver and then connect my phone and it should work?
  11. #11
    DroidXcon's Avatar
    Posts
    Global Posts
    11,645 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock for now
    Default
    Yeah but after you install the drivers put it in usb debugging mode then connect give it approx 4 mins to configure
  12. Thread Author  Thread Author    #12
    drmahou's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    [QUOTE=DroidXcon;960229]Yeah but after you install the drivers put it in usb debugging mode then connect give it approx 4 mins to configure
    Sent from my SCH-I510 using Tapatalk[/
    QUOTE]
    okay. I believe its automatically in usb debugging mode upon connecting
  13. #13
    DroidXcon's Avatar
    Posts
    Global Posts
    11,645 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock for now
    Default
    [QUOTE=drmahou;960231]
    QUOTE]
    If you need to toggle it its found at
    Settings> applications> development
  14. #14
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I wouldn't put it in my own PC if it wasn't safe, I know the site don't have all the fancy stuff, but it worked right away for me
    Sent from my Samsung Droid Charge using Tapatalk
  15. Thread Author  Thread Author    #15
    drmahou's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Thank you! Hopefully this works but i have to wait till Im home to try it
  16. #16
    AndroidXTC's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    None
    Default
    I have one more possibility that I just thought of. Do you have a case on the phone? If so I have one case that keeps the USB plug from going all the way in it allows the phone to charge but not USB connect. If you have a case remove it and make sure the cord is all the way in the phone.
  17. #17
    Farabomb's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Default
    Good point about the case. One of my curves was flaky like that. I also believe you can find the drivers if you have autorun set up. When I first plugged in my Charge it came up as a disk and I explored the folder and I'm pretty sure the drivers were in there.
  18. #18
    bellison41's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I had the same problem and I installed the drivers from one of the Rom\ Hacks for the Charge. I am also using Win7 and couldn't find the drivers. I didn't even see them on the Samsung site. So thank God the community of AC is the best. You can always find what you need or someone to help find it also.
  19. Thread Author  Thread Author    #19
    drmahou's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I know! Thank you guys so much!!! I have my droid working and Im using doubletwist to sync my itunes with my phone. It uses a lot of cpu though on the phone should. Does anyone have any suggestions for a different app.
  20. #20
    VZWTHUNDER's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Downloaded the files and it works for me
  21. #21
    Gordo68's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    It absolutely fixed my problems with my Asus UL80-vt and my charge. Now it recognizes it everytime.
  22. #22
    matty6288's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Connect connect to computer!
    this wont pull up for me? i cant figure out how to get my samsung charge to sync with my pc again, it use to. now nothing???
Tags for this Thread
