Lost my genious status when it took me 4 calls to figure out that you had to unlock the phone with the puzzle to answer..Any other way ?? Also does not seem to reliably answer in bluetooth mode when locked as well.. Ideas ??
Menu > Settings > Display Setting > Change lock screen
Then pick the sliding glass option.
Sent from my SCH-I510 using Tapatalk
