Results 1 to 25 of 25
    Default Holy Battery Drain, Batman!
    I've been testing battery life with different scenarios since I originally purchased my Charge nearly three weeks ago. Overall, I'd say that I'm pretty happy with how the battery performs on this device... comparing against what I've read elsewhere. I use the phone pretty lightly throughout the workday, and don't have to try too hard to get a full day of use out of it.
    Today, I decided to take a good look at battery consumption while streaming music. I don't typically use my phone in this fashion, but I know a lot of people do... so I was really curious how it would do.
    I was streaming radio using TuneWiki and noted the following. Both of these were with NO other usage, just left the phone streaming with nothing else running, and no screen time usage.
    Using 4G signal: I burned 20% of my battery in 1hr of use!!!
    Using 3G signal: I burned 10% of my battery in 1hr of use.
    I have noted a slight difference in 4G vs. 3G battery consumption through my tests, for my normal usage... but I'm the furthest thing from a heavy data user. I'm blown away by the difference while streaming... heck, I'm blown away by 10% consumption for 1hr of 3G. If I stream music all day at work on 3G, I'd be lucky to have any battery remaining by the time I get home. If I leave 4G on, I don't think I could make it to lunch.
    As a comparison, my typical use burns 2-5% battery per hour of use.
    Are there other streaming programs that are better on battery... or is this the norm?
  2. #2
    Default
    I have used Pandora streaming and only have lost approximatly 10% in about an hour. ymmv though depending on your signal strength. I usually run wifi when I can simply because its more efficiant.
    Default
    Unfortunately, I don't have any Wifi availability at work, so I'm stuck using 3G/4G. After this test, I'll be sure to use 3G only when streaming from here onward.
    I was 7hrs 15mins into my day and still had 76% remaining at that point
    One hour later, I was at 56% with the 4G streaming! Shocking.
  4. #4
    mboverst's Avatar
    Posts
    ROM
    EE4/Gummy 1.75/PBJ
    Default
    I've also noticed that those are killers on the batteries. I've also seen that using the navigation while unplugged eats it even faster! Thank goodness for car chargers or I wouldn't be able to get out of my neighborhood before it would be dead.
  5. #5
    Default Unusual rapid battery drainage (any recommendations?)
    I've had my Charge for almost a week now, and have installed the Altered Beast V4 ROM since day one. As far as I know the ROM isn't supposed to have any effect on battery so I'll have to consider that something else is draining the hell out of it. I tested it today with no apps running, bluetooth/wifi/gps off, 4G left on -- I averaged about a 6-9% drop per hour on a standby. I know the Charge isn't known for having great battery life, but surely this is out of the ordinary.
    The settings>about phone>battery usage section isn't much help. The usual suspects like the OS and such are at about 1-4%. The display hovers anywhere from 78-92%. Is that normal? I'm completely new to Android so I've no idea how to really manage the services and processes. Can anyone recommend an app I can download that may help me find the culprit? Or is it likely the fault of the battery or phone itself?
    Any help is greatly appreciated.
  6. #6
    Default
    Those numbers are about in par for the charge.
    Sent from Droid Charge using Tapatalk
  7. #7
    Default
    Are you sure? From what I'd read people averaged about 9-12 hours on average use. With my stats, I'd get those numbers without even turning on my display!
    Are there any particular settings people have on/off to get a decent run on a single charge? This is incredibly disappointing.
  8. Thread Author  Thread Author    #8
    Default
    I would completely disagree.
    This morning, for instance, I hit 90% at 4hrs. Most of this was standby, as I was at work, but shows what kind of battery drain the phone should see on standby in 4G.
    Now, I killed 20% during 1hr of radio streaming at 4G later in the day, but that's a different story.
  9. #9
    Default
    Quote Originally Posted by ellje View Post
    See, those are actually the numbers I would typically expect from this phone. But so far there's no way my particular model would ever just go down 10% in that amount of time. A third of my battery would easily be gone in the same timeframe. That's what has me worried.
    I'm doing a separate test now in airplane mode. As of now I'm at 2 hours and still at 100%. So it's looking like it really is the 4G. Even taking into account how much of a power drainer it is, I'm still not understanding why it would eat up so significantly on standby.
  10. #10
    Default
    Try downloading wheresmydroidpower from the market. The info it spits out is pretty comprehensive. My K9 mail was synching too much and was killing my batt.
    This message was sent via Tapatalk
  11. #11
    AndroidXTC's Avatar
    Posts
    ROM
    None
    Default
    Its a network issue, the Thunderbolt suffers from the very same erratic drain issue. My guess some flaw in there network keeps the phone awake at times.
  12. Thread Author  Thread Author    #12
    Default
    Quote Originally Posted by KassaNovaKaine View Post
    Could be a poor battery, or poor signal... those would be the big culprits, I'd suspect.
    Are you running any task killer or similar apps?
    Here's some settings that I run that may help you out.
    10% display when indoors
    No GPS, BT, WifI
    I keep data on, so my chat is active at all times
    I use gmail and manually sync (although yesterday I had auto-sync on, didn't notice a huge difference)
    30-second screen timeout
    No widgets
    The only thing I have syncing is gmail... I guess I don't care to be notified of everything that goes on in a day.
    If you can, at all, take it off the charger at 100%, and let it sit for an hour without turning it on. I'm curious what kind of battery drain you're seeing with the phone just sitting idle. If you have good 3G or 4G signal, it shouldn't be more than 4%.
  13. #13
    Default
    Quote Originally Posted by AndroidXTC View Post
    I keep all of the radio stuff off except bluetooth. It makes a huge difference. I live in a weak signal area at my house and think the receiver/transmitter radios are running full tilt trying to get a signal. I have also noticed when the network is turned on I get almost constant traffic activity(red/green arrows flashing). Is this normal? I am going to recheck my email settings to see if they are set to manual to get the constant network traffic to stop.
    When I want WIFI, or network connectivity I turn them on then turn them off when not needed.
  14. #14
    Default
    I do the same. Keep everything off until you need it. Everything syncs right up when you need it now. And don't use task killers or juice defender, and keep auto brightness off unless you really need it.
  15. #15
    delco714's Avatar
    Posts
    ROM
    Stock
    Default
    well, all of you look at you battery usage in settings.. 70-80% of the drainage is due to the screen! Maybe we shouldn't use the screen ;-)
  16. #16
    Default
    Nope. When left completely alone, here are the top apps running:
    Dialer - 3.17%
    LauncherPro - 2.62%
    Swiftkey X Beta - 1.44%
    Google Services Framework - 0.97%
    imo - 0.77%
    DoubleTwist - 0.51%
    The rest were below the .5% range, so should be negligible.
    No GPS, BT, WifI
    No widgets
    No GPS, BT, WiFi
    Data, 4G, Google locations services on
    Weather widget auto-updates every 4 hours
    Google, Pandora, DoubleTwist widget on homescreens
    Android Assistant/Wheres My Droid Power, only apps running
    After a full charge, I managed to go down from 100% to 86% in 4 hours. A much improved scenario over yesterday, but I'm still looking to make some tweaks.
    Would turning off mobile data and/or auto-rotation do much? It's either that or switching off the 4G for when I don't require it.
  17. #17
    Default
    Yeah, everything makes a difference. If you live in a 4g area, keep lte on, but just turn off mobile data and all the other radios when the phone is idle or you don't need it. Auto rotation uses a sensor, so I would imagine it makes some difference, I keep mine off until I need it, because it can be a little annoying at times.
  18. #18
    Default
    I started a thread about how pleased I was with the battery performance of my Charge. Several people who responded to that thread gave some good advice for getting the most from your Charge's charge. Check out the link below. I think you'll find some helpful suggestions.
    http://forum.androidcentral.com/sams...id-charge.html
  19. #19
    Mtn_Scott's Avatar
    Remain Calm!
    Posts
    ROM
    JB, JB, HC, ICS, JB
    Default
    Anything that pushes or pulls data will kill you battery more quickly. Steaming music is a constant data pull, so high battery usage. Any app that goes out looking for updates frequently will kill your battery as well. The big android phone user needs to weigh the desire to have instant updates vs. battery life. Widgets with auto updates are battery death. Apps with updates are the same, they are going to hit the network and drain the battery. The apps i want updating (gmail, weather, news) update once an hour, everything else only when I open the app. After making these behavioral changes i can get home with a half charge instead of a dead phone.
  20. Thread Author  Thread Author    #20
    Default
    Quote Originally Posted by Mtn_Scott View Post
    Can you tell me how you got your gmail to sync once every hour? I can't seem to find the option anywhere
  21. #21
    Question Draining Battery??...??
    This is the Exact same thing im experencing... i live in hawaii and we have to 4G yet so i dont think its That, i can go to work with phone at Full and after leaving house and getting to work it had dropped 8% and thats from just CHECKING my text messages.. i notice if i text alot my battery can drain about 20% within a 20 minutes.... i always have my wifi off, my gps stays on.. could that be the culprit..? in the settings about phone it says my display is 85% OS is 1% cell standby is 2% voice calls 3% android system 2% sensorserver_ya 1% phone idle 1%.
    i dont understand how this could drain so fast. i did flash my phone to the Altered Beast V4 ROM.....?? ANy Suggestions....?? Thanks -RobBie
  22. #22
    delco714's Avatar
    Posts
    ROM
    Stock
    Default
    I pulled my phone off charging at 100% and left it when i went back to sleep for 4 hours. It had wifi on pushing email every 5 minutes. The battery was at 98% at the end of the 4 hours.
  23. #23
    Default
    i just resigned my phone to being just a phone for txt messaging. ive turned all the features off minus wifi but mobile data and auto rotate are off . screen is at the lowest possible and i have removed auto sync on the phone. now the screen usage is a manageable 55% and im getting about 9 hours out of the battery. when i need to sync FB or email i turn the sync on and go from there. hopefully this helps you out
  24. #24
    Default
    Quote Originally Posted by robbie1288 View Post
    Is your auto brightness on? Because some people are saying that using auto brightness can be a really battery drainer.
  25. #25
    NHLou's Avatar
    Posts
    Global Posts
    111 Global Posts
    ROM
    Stock
    Default
    I think he may have been referring to the Samsung email app. From what I understand, GMAIL pushes the email to the phone once it is received.
    Google Mobile - Gmail
