Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By Jim101
    Default juice defender causing loss odf data connection
    juice defender was making my charge lose its data connection in and out of wifi. uninstalled and now it stays connected. not losing 4g/3g any longer.
  2. #2
    Default Re: juice defender causing loss odf data connection
    me too
  3. #3
    shaneneff's Avatar
    Posts
    Global Posts
    94 Global Posts
    Default
    Had to uninstall for this reason.
    Sent from my SCH-I510 using Tapatalk
  4. #4
    It seems to work on the Gingerbread leaks. I have been running for the last month or so and it was great. I switched back to EE4 due to the static issue while on a call and juice did not work well at all. I am on EP3 right now and it seems to be working just fine. Static is hit and miss though...
  5. #5
    Jim101's Avatar
    Posts
    Global Posts
    54 Global Posts
    Same problem here, had to "remove" it.....
    Jim
    davidfreeborg likes this.
  6. #6
    +1 on the uninstall. Ironically, my battery life is better and no longer do I have random resets (about 1 time a day).
    Tis a shame but... it is what it is. YMMV
    I am using EP1.
  7. #7
    Yeah i was getting an error about the data connection, I uninstalled it and no more issues.
  8. #8
    no problems here (stock). check your JD settings
  9. #9
    Quote Originally Posted by jco23 View Post
    what are we looking for, or need to change?
  10. #10
    Bob61's Avatar
    Posts
    Global Posts
    1,880 Global Posts
    I had JD on my DroidX, had great success with increasing battery life. I was hoping that HD on my Charge would let me squeeze a little more from the battery, but sadly I found the same thing, the data connection wouldn't turn on. I even tried the option included in JD to toggle the Mobile Data Connection, but no success. I ended up disabling the app and all is working well now. I hope JD developer can work around this issue in a future release.
  11. #11
    Bob61's Avatar
    Posts
    Global Posts
    1,880 Global Posts
    Then you are the lucky one as even the developer has confirmed there is a known problem with JD on Charge, see .
  12. #12
    Are you on EE4 or a GB leak? Froyo EE4 did not work for me but on Gingerbread, my 4g and 3g come back as expected with Juice Defender. I am on the EP3 debloated rom currently.
  13. #13
    i don't have a whole of developer/rooting apps - so that could be why I've done alright...
  14. #14
    Bob61's Avatar
    Posts
    Global Posts
    1,880 Global Posts
    Default
    Not really as the stock ROM causes the problem, using a ROM to GB would fix the problem, all info ad per the JD developer. Im stock as well as confirm the problem with stock.
  15. #15
    "works on mice too";-)
