Results 1 to 9 of 9
    Default Alternate lock screen?
    Is there any way to change the lock screen to something besides the puzzle piece or glass? I came from a Droid Incredible, and I didn't mind it's Sense lock screen, though I installed CM7 and loved the default android lock screen. But since I can't get CM7 on my Charge yet, is there any way to change the lock screen? Like maybe an app or something? I tried the app 'Widget Locker', but it was full of glitches and messed up more than it worked.
  2. #2
    z71kris's Avatar
    What does that do?
    Posts
    ROM
    Stock ICS
    Default
    To piggyback onto your thread is there a easy way to turn off the lock screen all together? I dont want to have to slide a puzzle peice or anything i just want to turn it on and use it.
  3. #3
    Default
    You don't need CM7 to use the stock AOSP launcher, you just need a deodexed rom and to take a look in the development section. And the two custom roms out now have it as an option, I'm using it right now on GummyCharged.
  4. #4
    Default
    Quote Originally Posted by z71kris View Post
    No you need a lock screen
    Sent from my Droid Charge using Tapatalk
  5. #5
    msw323's Avatar
    Posts
    Global Posts
    100 Global Posts
    Default
    Try No Lock. It's free from the Market
  6. #6
    Default
    No Lock doesn't work for me on the Droid Charge, and a few user reviews indicate that others can't get it working on their Charges either.
  7. #7
    Default
    Try this: http://forum.androidcentral.com/955482-post255.html.
    It worked on my stock ED2 Charge. But I found I kept bumping the power button and turning it on when I had the phone in a side pouch. I also missed the shut down screen options.
  8. #8
    Default
    Try Widgetlocker. You can make it look like any lockscreen you want and add shortcuts. Works on the charge.
  9. #9
    Default Re: Alternate lock screen?
    Quote Originally Posted by tazcordo View Post
    Yup, I'm using Widgetlocker and it's great. Good way to get your music player widget on your lockscreen as well so you don't have to unlock to pause/skip etc.
    Now I just need a way to change the call answer motion from the puzzle piece back to something like the stock android slider :/
