1. gohalos26's Avatar
    Hey there, I apologize if this topic has been posted before, but I searched the forum and didn't see anything...
    When I drag and drop new MP3's onto my Samsung Charge, I will get the following message on a third of the files:
    Sorry, this player does not support this audio file
    I've downloaded a few different players to see if this would go away, but I still have the same issue. Is there a fix/solution for this?
    Thanks in advance
    07-03-2011 09:26 AM
  2. yankees368's Avatar
    If you are using the official twitter app, uninstall, reboot, try again.
    xoxo_laura likes this.
    07-03-2011 10:06 AM
  3. gohalos26's Avatar
    No i am not using twitter, and it's not installed on my phone
    07-04-2011 02:05 AM
  4. Droid800's Avatar
    This happened to me today as well. Fixed itself about 10 minutes later though.
    07-04-2011 02:11 AM
  5. gohalos26's Avatar
    bump please.
    I don't have twitter
    07-04-2011 09:43 AM
  6. alwarrior#AC's Avatar
    I use TuneWiki as my music player. I also got the same message when I just droped my songs on the sd card. So I used windows media manager to rip the music, save it to a flie, then drop it on sd card. No more problems.
    07-04-2011 10:24 AM
  7. Droid800's Avatar
    What would twitter have to do with it?
    Sent from my SCH-I510 using Tapatalk
    07-04-2011 09:42 PM
  8. Droid800's Avatar
    Mine did this again tonight in the Samsung player, Google's new player, and in tunewiki.
    This is totally ridiculous.
    07-04-2011 09:44 PM
  9. hoppermi's Avatar
    I had this issue also. A reboot would fix for a while. I haven't had the issue in a while, working fine w/ gummycharged.
    07-05-2011 07:15 AM
  10. dgs2000's Avatar
    The twitter app is the culprit. Uninstalled it and problem went away completely. Ridiculous. I don't know if it's a twitter or Samsung problem to fix, and but they better get on it.
    07-05-2011 09:04 AM
