Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By Kevin O'Quinn
    Default Does S4 Pro have built in LTE ? or will there be 2 Radios
    There's quite a bit of concern on battery issues in the forums.. very hot button issue for many. As a Tbolt user I understand, it was the price I paid to have one of the first 2core/lte phones and a larger screen. That said my understanding was alot of battery is used due to it having two radio chips, I've read that some of the newer Chips now include LTE in the single silicon package. If this is the case I suspect that with improved SLCD3 power consumption that a 2500 ma would not be a issue at all.
    (my biggest battery drain is the radios trying to sync to service as I move around, my work location has pitiable cell coverage and I get alot of battery drain with the phone 'sitting' there.)
  2. #2
    radgatt's Avatar
    Posts
    Global Posts
    576 Global Posts
    ROM
    Stock
    Default Re: Does S4 Pro have built in LTE ? or will there be 2 Radios
    I hope so but I haven't heard anything.
    @workMakin$
  3. #3
    MG386's Avatar
    Posts
    Global Posts
    97 Global Posts
    no, the S4 pro Quad does not have integrated LTE modem like the S4 dual. it will be a separate chip
    Thanked by:
    This would then become more of a power consumption issue, while the cores/gpu themselves and display use less power it means when using LTE you'll be running 2 radios. Ok good to know all bit and pieces makes for better understanding my choices, thanks !
  5. #5
    Kevin O'Quinn's Avatar
    Posts
    Global Posts
    7,684 Global Posts
    ROM
    Stock
    Quote Originally Posted by jamdmyers View Post
    Actually the entire baseband is a separate chip. LTE, GSM, CDMA, it's all handled by an external baseband chip (mdm96xx i think), which is built on the same 28nm processor as the Krait core. Power efficiency should be good, since optimizations should be there to maximize performance between the two chips.
    In other words, Qualcomm designed it to be this way from the get-go.
    Forum Rules & Guidelines -- CLICK HERE
    I'm an NVIDIA Tegra Champ. Here's what that means. It means that from time to time I might receive products and/or services from NVIDIA to evaluate them and provide feedback to NVIDIA and you, our valuable members. What this does NOT mean is that my opinion will be biased. Any opinion that I express here and elsewhere are solely based on my personal preference and any relevant expertise that I may/may not have on the subject matter.
    seeingwhite likes this.
  6. #6
    Sooo does this mean it will have good battery life haha? (assuming 2500 MAH)
  7. #7
    DC Damien's Avatar
    Posts
    ROM
    CyanogenMod
    TBolt is single core, right?
  8. Thread Author  Thread Author    #8
    Yup, its been so long...
  9. #9
    The baseband chipset is separated from the SoC, it's MDM9615, smaller 28nm, and it handles voice, so there is no need for the secondary modem (fusion).
    That said, S4 dual had an integrated modem, but used the same exact ip stack from MDM9615, so there shouldn't be any difference in performance and battery life.
    Verizon 4G LTE
    http://i.imgur.com/gXryt.png
    Thanked by 2:
  10. #10
    Quote Originally Posted by DC Damien View Post
    Yeah it is.
  1. Can the built in Wi-Fi Hot Spot be hacked?
    By kelnhofer in forum HTC Vivid
    Last Post: 04-11-2013, 02:24 PM
  2. Does our phone have "alarm in silent mode" in alarm settings?
    By carole6m in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 05-21-2012, 10:12 AM
  3. Ice Cream Sandwich Will Have Built-in Advanced Photo Edit
    By nemov in forum Verizon Galaxy Nexus
    Last Post: 10-17-2011, 03:27 PM
  4. Droid, use built-in Facebook or Facebook off Marketplace?
    By sniffs in forum Android Applications
    Last Post: 02-23-2011, 09:28 PM
  5. Does the Pro have Gorilla Glass?
    By CSI Guy in forum Motorola Droid Pro
    Last Post: 01-01-2011, 10:17 PM
