Page 6 of 6 FirstFirst ... 3456
Results 126 to 146 of 146
Like Tree47Likes
  1. #126
    markymark's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Wait and SEE with 2020 mah battery
    Quote Originally Posted by Megaroad View Post
    The metal pieces on the sides don't join together in a uniform way. The metal also bulges out from the rest of the frame just slightly near the volume button. And the seam where the metal joins up with the plastic on the front and the kevlar on the back isn't consistent - sometimes it's touching perfectly and sometimes there's a very slight space there.
    The first one I got had these problems in a kinda pronounced way, so I exchanged it (at a different store, actually) and the guy there opened up a number of boxes for me and they all had slight flaws to one degree or another. Don't get me wrong, I like the phone, but the build isn't quite at the level that it should be imo, especially since the materials are so nice.
    I see. Thanks. I plan to put a silicone gel case on it anyway so no big deal.
    Who? likes this.
  2. #127
    markymark's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by badbrad17 View Post
    I think think S3 is still the best phone for covering all bases. It's still has certain things that could be better but these are subjective. For me I prefer the IPS LCD display over AMOLED, but other than this the S3 is about as close to perfect as you can get. Had the One X had a bigger battery it maybe even more perfect.
    Sent from my SGH-T989D using Android Central Forums
    The S3 for me was a little too big and felt plasticky. I prefer the form factor of the Maxx HD and I think it's just a much better looking phone and felt more solidly built. Of course it's subjective. Plus I read that the radios on the S3 are not as good. A phone is only as good as the signal.
    Who? and badbrad17 like this.
  3. #128
    varucell's Avatar
    Posts
    Global Posts
    195 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I plan on buying the DNA from best buy. I am going to see if it gets me through the day for a week or two. If it doesn't then I will get the note 2
    Who? likes this.
  4. #129
    Who?'s Avatar
    Posts
    Global Posts
    400 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by varucell View Post
    I would recommend that you wait until the 27th and then have Best Buy price match the Amazon price (program is suspended until then) , you'll likely save a nice amount of cash. Many people have saved money doing this for the razr maxx HD, although just to be safe I should say YMMV.
  5. #130
    bellken's Avatar
    Posts
    Global Posts
    311 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Even my Droid 2 with a 1440 mAh battery could go 30 hours on a charge with "light usage." The test is how well it lasts when you need to use it a lot. I'm basing my opinion on A) reviews, B) my assumptions about powerful screen vs. average battery and C) my lack of believe that HTC has suddenly found a formula that is dramatically more efficient than Samsung's, Motorola's, and Apple's.
    I hope you get the chance to use a DNA, I think it might change your opinions. I know it changed my opinion. And, it should be noted, that I did not claim the DNA is much more efficient than the newer Samsung, Motorola or Apple phones. I only claimed it was for efficient than the 1st gen LTE devices.
  6. #131
    bellken's Avatar
    Posts
    Global Posts
    311 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I started this morning at 6:30 pst with 36% battery, with normal usage, including downloading a 128 mb update for Reign of Amira, I am down to 21% battery. In about 3:30 I used 15% battery, this includes about 10 minutes in an area of poor LTE coverage. This is real world usage, ymmv.
    mclarryjr and badbrad17 like this.
  7. #132
    bellken's Avatar
    Posts
    Global Posts
    311 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    At 19% (light usage) right now, and, I just plugged in one of these to test - http://forums.androidcentral.com/e?l...token=A5ZuhJxW
    my power pack was charged up in August, but, all of the little leds were on, so, I will give it a test.
  8. #133
    bellken's Avatar
    Posts
    Global Posts
    311 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    just noticed, the phone stopped charging. it got up to a 51% charge. The power pack is drained, in about 1:40 and, it only boosted my battery from 19% to 50%. I may need a bigger charger.
  9. #134
    Who?'s Avatar
    Posts
    Global Posts
    400 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Wow, four straight posts. No edit button on your DNA?
  10. #135
    bellken's Avatar
    Posts
    Global Posts
    311 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by whatwhat View Post
    I could edit, but, I thought the time posted might be relevant.
    badbrad17 likes this.
  11. #136
    bellken's Avatar
    Posts
    Global Posts
    311 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    95% charged now, using an AC charger. In one hour and 20 minutes, the charge on my phone went from 50% to 95%. My lazy math says, it would take about 3 hours to fully charge the batttery. In case someone is interested in how long it takes to charge up a DNA.
    dsignori likes this.
  12. #137
    badbrad17's Avatar
    Posts
    Global Posts
    3,267 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock JB 4.4 Rooted
    Quote Originally Posted by Dieter Bohn View Post
    You're mean
  13. #138
    Cobravision's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by bellken View Post
    You will lose 30% of the charge from the battery charger due to inefficiencies. So if you have a 2100 mAh battery pack, you won't get more than 1470 mAh charge from it. To fully charge a 2020 mAh battery, you will need a 2900 mAh battery pack.
  14. #139
    dsignori's Avatar
    Posts
    Global Posts
    1,706 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks !!!
    Wingznut likes this.
  15. #140
    dsignori's Avatar
    Posts
    Global Posts
    1,706 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You're mean
    Did you intend to link to a 2008 post here?
  16. #141
    milan03's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    FYI, the battery life on DNA is just a tad better than Verizon version of Samsung Galaxy S3. If you're fine with SIII battery life, you'll be just fine with DNA.
  17. #142
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Something JB
    Quote Originally Posted by dsignori View Post
    I did a double take too...
    Sent from my X-Band Modem... TY Genesis
  18. #143
    Megaroad's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by milan03 View Post
    It takes some selective use of reviews to arrive at that conclusion.
  19. #144
    milan03's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Well, trusted reviews are coming soon. We'll see.
  20. #145
    badbrad17's Avatar
    Posts
    Global Posts
    3,267 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock JB 4.4 Rooted
    Lol. Not sure what happened there. Was posting on something else. Sorry. :banghead:
  21. #146
    badbrad17's Avatar
    Posts
    Global Posts
    3,267 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock JB 4.4 Rooted
    Quote Originally Posted by piizzadude View Post
    I posted from the post from "whatwhat" who said " Wow, four straight posts. No edit button on your DNA?"
    Nothing serious. Just my usual useless drivel. Sorry.
    Wingznut and Who? like this.
  1. People with the 4800 mah battery, question!
    By zkyevolved in forum Dell Streak
    Last Post: 05-30-2011, 08:50 AM
  2. Wait and see Battery life method
    By Edwill86 in forum Verizon HTC Thunderbolt
    Last Post: 03-31-2011, 04:48 PM
  3. Get an Evo now, or wait and see?
    By ilongbored in forum HTC EVO 4G
    Last Post: 11-18-2010, 09:10 PM
  4. 2150 mAh battery and I LIKE IT!!!!
    By huey in forum Incredible Accessories
    Last Post: 07-01-2010, 04:52 PM
  5. 1800 mah Battery AND stand-alone battery charger
    By mr.s4ndm4n in forum Incredible Accessories
    Last Post: 05-19-2010, 02:22 PM
