How well does it run? Snappy? Compared to gs3, one X, nexus 4?
Sent from my ADR6425LVW
In initial use, it's very fast. Need to mess around with 1080p video some more.
So, what is the 'extra' little hole on the back? A sound cancellation thingy"
How is the notification light? Is it multi-colored? Does it suck (comparatively) like other HTC devices?
Thanks!
Is it just me or is the bloatware extra bloaty this time around?
1. How's the GPS signal? My S3 sucks.
2. If I can get $450 for my S3, would you recommend buying the DNA?
Sent from my SCH-I535 using Android Central Forums
even if battery life werent poor,which i am pretty sure it will be,11gb of usable storage make this device as great as all the rest seems to be,absolutely useless,shame on you,stupid HTC.
People want bigger batteries and sd card slot or at least 32gb,is it that hard to get?
Phil, what version of Sense is it running?
Sent from the cockpit of Gurren Lagann
Phil, Would you recommend this over nexus 4 just based off the hardware?
Sent from my Transformer TF101 using Android Central Forums
it could have been if the IDIOTS at HTC put a 3300mah battery like maxx. boom, done stamp!!
What's the deal with the Amazon app store situation? Am I correct in assuming the Play Store is on it as well? Can apps be disabled like should be able to?
Hunh? This is all standard stuff. Yes it has Google Play. Yes, you can load the Amazon app store. Yes, you can disable apps.
