ohio2010
I travel quite a bit and would like to know if you can watch an entire movie 2+ hrs (in airplane mode) and still have battery to call a cab once on the ground.
If you do not run the brightness at 100% for the entire 4-5 hours, I believe it will. Also, are you gaming/watching video, or just using web/widgets? I think it depends on what your are doing, but I also believe this phone will handle it. If you can give me an idea of what you will be doing I can run some tests.
cloud, cloud, cloud. If you need music that bad and do not have cell or wifi get a $20 mp3
So if the phone as gorilla glass, does that mean it won't scratch and won't need a screen protector??
Will get ya a pic later. But the DNA's a little more red than the Nexus 4, whose whites are decidedly whiter. Both are better than the GNex.
do apps fit the screen normally?
It comes with 5 home screens, but you can add two more. The wallpaper does not scroll, it remains static, like it did on the Rezound.
OK, so for everyone complaining about Storage, here are screen shots of how much space i am using....
View attachment 46498View attachment 46499
How much space are you REALLY using???? i think i could fit everything i need on the DNA and still have space.
Good question. How are apps and web sites scaling to the new resolution. Is the experience pleasant in terms of quality.
Sent from my SCH-I535
