As the title says, can you customize or change the lock screen icons.
The last Sense phone I had was an Inc2. I wouldn't be using their text messaging app or their browser.
Thanks!
Printable View
Thanks!
changing the icons on the dock changes the lockscreen icons
Phil's review says no, you cannot.
This will be added upon a rooted ROM image you can be certain.
Hmm, so which one is it? Ha.
Change Icons on the dock changes home screen icons....works with most all latest htc phones....
Thanks guys. This is kind of important to me if I'm gonna make the switch. I hate wasted configurations like that.
Buenos got it right, I had to think since it had been awhile, I use Handcent as text app... needed to get that on the lock screen
Unfortunately, this did not work for me. Not sure what the deal is.
You definitely can change the icons on the lock screen. As has been noted by others, whatever you have in the dock (the little bar at the bottom of your home screens) is what will show up on the lock screen:
[Only registered and activated users can see links. Click Here To Register...]
Yes you can change them out.....the ONLY Htc Phones ON Verizon that allow you to have 2 diffrent sets of Widgets are the Rezound running 4.0.4. With Sense 3.6 and the ThunderBolt running the same software.
