Page 6 of 31 FirstFirst ... 3456789 ... LastLast
Results 126 to 150 of 763
Like Tree504Likes
  1. Thread Author  Thread Author    #126
    Mooem's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Post your home screens!
    Changed things up a bit...instead of putting it all on one screen, decided to make use of multiple screens.
    I just wish I could easily modify the status bar to be semi-transparent like it is on the stock sense launcher. That ugly textured grey ruins the look of it, wish HTC would get rid of it and at least make do with pure black.
  2. #127
    osubeavs728's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks smooth and dj. Looks like I have some work to do today
  3. #128
    KingofHeart4711's Avatar
    Posts
    Global Posts
    751 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by jedge View Post
    http://img819.imageshack.us/img819/9...2112422411.png
    *p.s., if this is anyone else's first ICS phone the screenshot function is a bit tricky at first. As the op wrote, you press the power and volume-down buttons at the same time. Took me a few tries to get it (phone kept turning off). Try to press them both at the exact same time and hold them down for about 1/2 second, let go, wait another 1/4 second and you'll hear/see the screenshot being taken. It'll be in your Gallery. Even easier, your last screenshot will show in your notifications... with a handy "upload" button too! I love ICS!, can't wait for JB.
    Actually you can just hold the power button and tap the home button =) I find it easier then holding power and volume dow 3 seconds
  4. #129
    heath patrick's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    nextcity and Vern441 like this.
  5. #130
    mclarryjr's Avatar
    Retired Moderator
    Posts
    Global Posts
    6,549 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    NOS M7 Sense 5.0
    Sent from my HTC6435LVW using Tapatalk 2
    harryjhun likes this.
  6. #131
    dsignori's Avatar
    Posts
    Global Posts
    1,706 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Post your home screens!
    Quote Originally Posted by KingofHeart4711 View Post
    True, but that sequence does not leave the resulting screenshot in your notification area for immediate viewing and/or sharing (oddly).
    The power/Volume Down combo does. Quite odd actually that the results differ. For me the Volume Down method is much more useful.
  7. #132
    HardRock4's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    @mclarryjr What widget are you using for the date/time and weather? Thanks.
  8. #133
    8100User's Avatar
    Posts
    Global Posts
    191 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for this tip! That's why I love browsing these threads... I always pick up new tips!
  9. #134
    chuch13's Avatar
    Posts
    Global Posts
    121 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by matthewdlyons View Post
    What are the calendar and time/weather widgets? They're nice.
    Zooper Widget Pro
  10. #135
    Pierpoint's Avatar
    Posts
    Global Posts
    124 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    ConTejas and robbies7897 like this.
  11. #136
    mclarryjr's Avatar
    Retired Moderator
    Posts
    Global Posts
    6,549 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    NOS M7 Sense 5.0
    @Hardrock4
    The widget is UCCW (Ulitimate Custom Widget) and the theme is HTC / ICS ish and they can both be found in the play store for free. If you search UCCW Sins you will find a ton of free and paid skins.
    HardRock4 likes this.
  12. #137
    casualpogs's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mclarryjr View Post
    @Hardrock4
    I really like your lock screen. Is that the same widget for the lock screen?
  13. #138
    mclarryjr's Avatar
    Retired Moderator
    Posts
    Global Posts
    6,549 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    NOS M7 Sense 5.0
    Quote Originally Posted by casualpogs View Post
    Lock screen is just the stock 4.2 which is on the rom UKB DNA 1.0.0 I'm currently running, they also have mods that lockscreen but to do either you have to be rooted.
  14. #139
    casualpogs's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Welp, looks like I'll be rooting soon. Thanks for the info
  15. #140
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Bit off topic but on the subject of rooting have you tried any Wifi tethering apps, or better yet are any compatible with the DNA.
  16. #141
    mclarryjr's Avatar
    Retired Moderator
    Posts
    Global Posts
    6,549 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    NOS M7 Sense 5.0
    Quote Originally Posted by heath patrick View Post
    Haven't tried because I use a Jetpack. You could look around rootz mabybe they have something posted there.
  17. #142
    Ryandroid86's Avatar
    Posts
    Global Posts
    804 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    you dont have to root.... https://play.google.com/store/apps/d...51bGwsMSwyLDNd
    Im using the Holo locker and the APEX launcher (on the HTC one S)
ID:	50099Click image for larger version.
    bdeitemeyer and mclarryjr like this.
  18. #143
    Ian Chandler's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It is NFC enabled notification. disable NFC to get rid of it.
  19. #144
    nextcity's Avatar
    Posts
    Global Posts
    194 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Mooem View Post
    Updated the OP with instruction. Press and hold the power button + volume (down) at the same time.
    There is another easier way to take screenshots. First press and hold the power button, then press the home key.
  20. #145
    hell_on_heels's Avatar
    Posts
    Global Posts
    348 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by nextcity View Post
    Is this for the gs 3?
    O_o WISHING I HAD WAITED AND GOT THE NOTE 2, ANYONE WANNA TRADE? o>_
  21. #146
    mclarryjr's Avatar
    Retired Moderator
    Posts
    Global Posts
    6,549 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    NOS M7 Sense 5.0
    UKB 1.1 Rom with added app drawer size, centered clock, battery percent, butterfly wallpaper & widgets.
    And much more
  22. #147
    FD2
    FD2 is offline
    FD2's Avatar
    Shadow Lurker
    Posts
    Global Posts
    376 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Anything broken in the ROM Larry?
  23. #148
    mclarryjr's Avatar
    Retired Moderator
    Posts
    Global Posts
    6,549 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    NOS M7 Sense 5.0
    Just updated to 1.1 an hour ago and don't see anything yet and ran 1.0 for almost a week without any issues. Also Chingy has a rom he just released a few days ago that looks pretty good too just haven't had the time to try it.
  24. #149
    FD2
    FD2 is offline
    FD2's Avatar
    Shadow Lurker
    Posts
    Global Posts
    376 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Going to try it. Thanks
    mclarryjr likes this.
  25. #150
    lilmoney30#WN's Avatar
    Posts
    Global Posts
    55 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sent from my HTC6435LVW using Android Central Forums
    Attached Thumbnails Attached Thumbnails Post your home screens!-uploadfromtaptalk1355261850507.jpg
  1. Post your home screen if you can.
    By Captian4Phones in forum HTC Vivid
    Last Post: 11-01-2012, 12:14 PM
  2. Post your home screens!
    By goldkear in forum Google Nexus 7 Tablet (2012)
    Last Post: 07-20-2012, 08:01 AM
  3. Post Your Home Screen v1.1
    By BiafraRepublic in forum Virgin Mobile Optimus V
    Last Post: 09-09-2011, 12:05 PM
  4. Post your home screens!!!!
    By shawnf1986 in forum Virgin Mobile Optimus V
    Last Post: 03-17-2011, 04:13 AM
  5. Post your home screen
    By dougau in forum LG Ally
    Last Post: 03-13-2011, 09:16 PM
