Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By Phil Nickinson
    Phil Nickinson's Avatar
    Android Central Editor in Chief
    Posts
    Global Posts
    3,439 Global Posts
    Default Droid DNA and multitouch (no, it's not broken)
    I've had a few people ask about multitouch on the Droid DNA, suggesting that it's broken and won't recognize more than two points. This is incorrect.
    (And, frankly, I should have figured it out on my own.)
    To connect to HTC MediaLink, you do a three-finger swipe on the screen. So we know it can recognize more than two points. The catch is that this keeps other applications from recognizing those third, fourth and fifth touches. However, if you turn on the "show touches" option in the ICS+ developer settings, you can clearly see the phone is recognizing more than two points.
    To "fix" things for other applications (and are there really that many apps that need three or more touchpoints? Probably more than I think.), go to Settings>Display & Gestures and uncheck HTC Gestures. That's it. Apps will now recognize more than two touchpoints.
    This works on the One X and One S as well.
    Thanked by 2:
    Fraggle79 likes this.
  2. #2
    Default Re: Droid DNA and multitouch (no, it's not broken)
    Thanks!
  3. #3
    This stuff shouldn't even be stuff users have to discover or change settings for. It should just work out the box.
    Carrier: AT&T | Device(s): HTC One 64GB & Galaxy S4
    "I don't always use a launcher, but when I do I use Nova"
    The Basics: Unlocking and Rooting - http://forums.androidcentral.com/htc...hing-roms.html
    Unlocking and Rooting AT&T and Int'l HTC One - http://forums.androidcentral.com/htc...nal-model.html
    Posts
    Global Posts
    3,439 Global Posts
    Quote Originally Posted by scorpiodsu123 View Post
    Guess it depends if you do anything that needs more than two simultaneous touches. I've gone months without even noticing. So for me? NBD.
  1. NEW UPDATE for 10.1 no it's not Touch Wiz
    By genkilljoy in forum Samsung Galaxy Tab 10-inch
    Last Post: 08-24-2011, 07:13 AM
  2. Replies: 15
    Last Post: 05-19-2011, 10:40 PM
  3. No it's not an iphone
    By perthcomputerhelp in forum Introductions
    Last Post: 01-03-2011, 06:38 AM
  4. Help! Static on three Droids and now no 3G...
    By Nats713 in forum Motorola Droid
    Last Post: 01-22-2010, 07:40 PM
  5. Replies: 20
    Last Post: 12-22-2009, 10:13 AM
