When you go to settings, battery and then usage it shows what percent of what has used the battery. What are the x's for on right side. If you click them they go from black to like a greyish color. Any input is appreciated
Printable View
I believe those Xs are for terminating individual tasks. You'd use that if you found that an app or task was using an extraordinary amount of battery power.Quote:
Originally Posted by PitbullJunkee [Only registered and activated users can see links. Click Here To Register...]
Sent from my HTC Droid DNA via Tapatalk 2
