Results 1 to 2 of 2
    jdtftp1's Avatar
    Posts
    Global Posts
    74 Global Posts
    Default battery usage stats
    When you go to settings, battery and then usage it shows what percent of what has used the battery. What are the x's for on right side. If you click them they go from black to like a greyish color. Any input is appreciated
  2. #2
    Default Re: battery usage stats
    Quote Originally Posted by PitbullJunkee View Post
    I believe those Xs are for terminating individual tasks. You'd use that if you found that an app or task was using an extraordinary amount of battery power.
    Sent from my HTC Droid DNA via Tapatalk 2
  1. Battery usage stats issue...
    By jonvito2 in forum Verizon HTC Rezound
    Last Post: 04-06-2012, 02:51 PM
  2. Battery usage stats force close observation
    By draftpeppin in forum Motorola Droid X
    Last Post: 12-21-2010, 08:05 PM
  3. Need suggestion on app to track battery usage
    By Carioca_FL in forum Android Applications
    Last Post: 06-12-2010, 02:07 PM
  4. Lag and battery usage...
    By TylerLannan#AC in forum HTC Hero Rooting, ROMs, and Hacks
    Last Post: 03-12-2010, 10:43 PM
  5. battery usage
    By bmderuosi in forum Motorola Droid
    Last Post: 11-18-2009, 11:16 PM
