Results 1 to 5 of 5
- 11-23-2012, 07:43 AM
Thread Author #1
new to android and DNA - need help
Trying to copy a ringtone mp3 into /system/media/audio/notifications, using Astro File Manager. Fails to write file. All of the pre-loaded ringtones are stored under system.
Do I need to root this phone to copy ringtones and like files?
Also, I see a directory structure under sdcard, which has directories for ringtones, notifications... I can copy a file there, but cant see the mp3 in the Sounds menu. What is the purpose of this directory structure if the phone doesnt see the mp3 I added.
Sorry, really confused on how to simply copy a file so that I can add a ringtone.
thanks - 11-23-2012, 07:57 AM #2
Re: new to android and DNA - need help
You don't need to copy the mp3 a specific folder - anywhere on the phone will do.
Go to Settings -> Sound -> Phone ringtone
There is an "Add" button in the top right corner. Press that and you should be able to add any mp3 found on your phone as a ringtone.You can always achieve your goal by lowering your expectations. - 11-23-2012, 08:02 AM
Thread Author #3
I see the ADD + from the Ringtones menu, but I dont see anything to add once I click on it. There is no way to browse to select anything else. I dont see the ADD + in the Notifications menu.
- 11-23-2012, 08:14 AM #4
Yeah, if you are new to Android it will take you a few days of playing to figure stuff out.
Most of the advance settings for apps are hiding away in the 'menu' (the icon looks like 3 vertical dots).
Also, be aware that HTC Android phones have a custom skin called Sense+ (in your case) running on top of Android. The look and feel of Sense+ is different to stock / standard Android, but mostly everything still works the same way.You can always achieve your goal by lowering your expectations. - 11-23-2012, 08:31 AM
Thread Author #5
New to Android, and need help please
By m.seif in forum Other Sony Android PhonesReplies: 0Last Post: 07-11-2012, 06:19 AM -
New to Android and Need some help
By Gennarelli in forum General Help and How ToReplies: 9Last Post: 05-29-2011, 11:18 AM -
I'm New to Android and Got 3 Questions - HELP
By koolx in forum Android ApplicationsReplies: 4Last Post: 02-21-2011, 08:21 PM -
new to android and need help finding an app
By spongey600 in forum Android ApplicationsReplies: 3Last Post: 01-13-2011, 08:24 PM -
By spongey600 in forum General Help and How ToReplies: 1Last Post: 01-13-2011, 07:00 PM
Reply
