Anyone else notice any light leaking from the very bottom bezel below the buttons. Didn't bother me at first but now it is all I notice.
Printable View
Don't have that issue, if it's bothering you go exchange it.
Yeah. After owning a nexus 7. I'm use to it.Quote:
Originally Posted by Sooks [Only registered and activated users can see links. Click Here To Register...]
Sent from my HTC6435LVW using Android Central Forums
Nope. If it exists, I don't notices it. Then again, I don't notice it on my Nexus 7 either. If I did notice it, I wouldn't hesitate to exchange it though.Quote:
Do you mean the light from behind the Capacitive buttons?Quote:
from my Galaxy Note 2, baddest phone on the planet.
Rezound has same issues. Live with it or exchange it.
Sent from my ADR6425LVW using Android Central Forums
HTC seems to have issues with sealing the display. It's either light leak or dust accumulation. Frustrating.
I can't say that I've noticed any light leaking.
No issues on my display.
None here.
The Nottinator
Have it with my thunderbolt. I've gotten use to it
