Results 1 to 4 of 4
    Default DNA + USB Thumb Drive
    Can anyone successfully use USB flash drives, and if so, please tell me which partition did you use! I've tried exFAT, loaded a movie, the drive is invisible in Astro... Same with NTFS. Finally tried FAT32, no dice.
    What app do you use to browse the content of the external storage? What path? I'm lost!
  2. #2
    bellken's Avatar
    Posts
    Global Posts
    311 Global Posts
    Default Re: DNA + USB Thumb Drive
    I use Astro. I select My Files -> FOLDERS. My usb drive shows up in the list. You will need to look for it, it is listed as /storage/usb/...
  3. #3
    From what I've read it has to be FAT32 partition, so no files over 4GB will be a limitation for some people.
    Astro seems to be what others are using successfully to manage their files.
  4. #4
    That's 4gig max per file, you can have as many files as you'd like, I use a 32gig micro as in a adapter. 4 gig for hdef vid might be a issue but even big games are far less
  1. Eject USB Thumb Drive Safely in ICS?
    By jsigmo in forum Samsung Galaxy S II Skyrocket
    Last Post: 05-14-2016, 04:41 AM
  2. Usb adaptor for thumb drive
    By Nychotxxx in forum Google Nexus 7 Tablet (2012)
    Last Post: 08-01-2012, 09:31 AM
  3. can't find usb/thumb drive/external hard drive
    By jharo in forum Acer Iconia A500
    Last Post: 10-08-2011, 03:11 PM
  4. Unmounting USB thumb drive
    By pduffer in forum Acer Iconia A500
    Last Post: 07-26-2011, 12:15 PM
  5. 3.2 does not support USB thumb/flash drive
    By atz06 in forum Motorola Xoom
    Last Post: 07-13-2011, 02:00 PM
