simultaneous voice and 3g data
jjmogul25#AC
7
Hi does anyone know if the DNA is supposed to support simultaneous voice and data while on 3g network I know that it works with 4g my question is if it also works while on a 3g network.
anon(94115)
Banned
Nov 29, 2010
5,697
511
I believe it does. The thunderbolt kicked that off and everything that I am finding says that most of the Android phones that run on LTE with VZW have the capability....now the iPhone 5 does not have that ability....
anon62607
436
27
Oh so you are saying that you are going to be 3G only (no LTE into the equation at all)?
Not sure about that one since voice is 3G...
On Verizon voice is carried on 1xRTT, not 3G ( EVDO ). On gsm 3G systems voice can be carried on HSPA, and is usually carried at higher quality as well.
Sent from my HTC6435LVW using Tapatalk 2
anthony2558
1,607
90
No it does not work. Talking on the phone and surfing the net does not work over the 3G network. But does work on the 4G network.
jjmogul25#AC
7
Why is it different then the rezound which worked simultaneously on 3g as well and the galaxy s3 also works.is there a reason this phone is different
bellken
320
20
The DNA does not have a separate radios for CDMA and LTE. The Rezound does have a separate radios for CDMA and LTE, which is why turning off LTE helped the rezound save power. The integrated radios is one of the reasons we are seeing better battery life for the DNA.
edoublediz
Banned
Jan 26, 2010
1,144
117
The SGS3 does work with 3G and data, I just tested it out.
what do you mean you just tested with 3g and data?
while you were on 3g service, not 4g or wifi, you were able to browse internet while on a call? i am almost certain, it does not. i have never heard anyone say it does. i didnt own it long enough to tell.
anon(94115)
Banned
Nov 29, 2010
5,697
511
I am on Sprint which is cdma, just like vzw.
Yes, I turned off 4g,had to reboot, turned off wifi, made a call to my voice mail, hit the home button and went to espn. Saw how badly the Steelers lost and laughed
Sent from my X-Band Modem... TY Genesis
dsignori
2,540
40
48
Interesting, thanks. This is the very first I have heard of this on CDMA. Maybe I wasn't paying attention, because I swore I read that users could not do this with the GS3 on CDMA. Anyway thanks !
anthony2558
1,607
90
I just tried it myself on the Verizon GS3 and it works. WiFi off, 3G only. Made a call and searched Internet at same time.
AmeliaRodriguez
