Hi does anyone know if the DNA is supposed to support simultaneous voice and data while on 3g network I know that it works with 4g my question is if it also works while on a 3g network.
Printable View
I believe it does. The thunderbolt kicked that off and everything that I am finding says that most of the Android phones that run on LTE with VZW have the capability....now the iPhone 5 does not have that ability....
What I'm trying to figure out is if it works when on the 3g data network not while on the LTE data network
Oh so you are saying that you are going to be 3G only (no LTE into the equation at all)?
Not sure about that one since voice is 3G...
On Verizon voice is carried on 1xRTT, not 3G ( EVDO ). On gsm 3G systems voice can be carried on HSPA, and is usually carried at higher quality as well.Quote:
Originally Posted by piizzadude [Only registered and activated users can see links. Click Here To Register...]
Sent from my HTC6435LVW using Tapatalk 2
No it does not work. Talking on the phone and surfing the net does not work over the 3G network. But does work on the 4G network.
Why is it different then the rezound which worked simultaneously on 3g as well and the galaxy s3 also works.is there a reason this phone is different
The DNA does not have a separate radios for CDMA and LTE. The Rezound does have a separate radios for CDMA and LTE, which is why turning off LTE helped the rezound save power. The integrated radios is one of the reasons we are seeing better battery life for the DNA.Quote:
Originally Posted by jjmogul25#AC [Only registered and activated users can see links. Click Here To Register...]
I stand corrected. Everything I saw pointed to yes
Sent from my X-Band Modem... TY Genesis
And the galaxy s3 does work simultaneously?
nope, only a couple of phones do. it must have SVDO radioQuote:
The SGS3 does work with 3G and data, I just tested it out.
what do you mean you just tested with 3g and data?Quote:
while you were on 3g service, not 4g or wifi, you were able to browse internet while on a call? i am almost certain, it does not. i have never heard anyone say it does. i didnt own it long enough to tell.
I haven't heard this either. You have a VERIZON GS3 and used data and voice concurrently?Quote:
I am on Sprint which is cdma, just like vzw.
Yes, I turned off 4g,had to reboot, turned off wifi, made a call to my voice mail, hit the home button and went to espn. Saw how badly the Steelers lost and laughed
Interesting, thanks. This is the very first I have heard of this on CDMA. Maybe I wasn't paying attention, because I swore I read that users could not do this with the GS3 on CDMA. Anyway thanks !Quote:
No sweat.
I am pretty sure I could do it on my Charge as well...
I just tried it myself on the Verizon GS3 and it works. WiFi off, 3G only. Made a call and searched Internet at same time.
i stand corrected!
Do I get an "I told you so" from the beginning of this thread?
Nah, I wouldn't do that.....
Go Browns! :)Quote:
lets not go to far...
LOL. i could take it!Quote:
It seems that the HTC designers were really bent on making the DNA as thin as possible and made cuts to achieve that profile.Quote:
Originally Posted by bellken [Only registered and activated users can see links. Click Here To Register...]
They left out the sd card slot (with encouragement from VZW), the separate cdma radio, and used a slimmed down battery.
How thin, is thin enough?
Sent from my ADR6400L using Android Central Forums
Of all the various things that folks have complained about on this phone, the lack of simultaneous voice/data in 3g areas is an absolute deal-breaker for me. I could deal with 11 Gig of usable space and a sealed battery, but what i cannot deal with is working in rural areas of Michigan and not being able to function as well as I can with the Thunderbolt. (Can't believe I just said that.) I find myself talking & searching maps or technical documents all the time. If I couldn't do both simultaneously, I'd be hosed.
