Results 1 to 8 of 8
    nismo591's Avatar
    Posts
    ROM
    Stock
    Default Battery percentage indicator bug
    Anyone notice after charging their phone wirelessly that the notification in the task bar and any widget that displays the battery percentage stays at 99%? The only way to get it to correct itself is by reseting the phone. I know it's not a huge deal but bugging the heck out of me.
    Attached Thumbnails Attached Thumbnails Battery percentage indicator bug-screenshot_2012-11-27-10-23-24.jpg
  2. #2
    Default Re: Battery percentage indicator bug
    Can you see if the settings menu for the battery has it properly? I haven't noticed any issues, but I thought I saw a slight discrepancy between what the settings menu was showing and what the status bar was showing one time.
    nismo591's Avatar
    Posts
    ROM
    Stock
    Default
    Quote Originally Posted by scarrow666 View Post
    If I go into settings then battery it shows properly but the drop down indicator in the notifications does not. This only happens after wirelesslyccharging it overnight. A restart always fixes it though.
  4. #4
    cjmac97's Avatar
    Posts
    Global Posts
    31 Global Posts
    I wirelessly charge every night using a Nokia DT-900 but haven't seen this problem.
  5. #5
    I'm using the Energizer pad and also don't have issues (finally had my battery power low enough last night to see).
    Sent from my HTC6435LVW using Tapatalk 2
    nismo591's Avatar
    Posts
    ROM
    Stock
    Default
    I'musing the lg Verizon branded charger. I was contemplating doing a factory reset to see if it fixes the issue. It does it every time I charge the devicetthat way so I can at least say it's not an intermittent issue.
  7. #7
    Tested it today since I use the LG also, all seemed to track ok over the day went from 99 to 76 and the 'icon' looked similar to what 'battery' in settings looked like. I'll be flashing a mod that shows actual % later tonight.
  8. #8
    Quote Originally Posted by cjnyc View Post
    Yeah, Yeah me too! Flawless in every way for me!
  1. Battery Percentage instead of battery icon?
    By Crafty_Ute in forum HTC EVO 4G
    Last Post: 12-23-2011, 03:20 AM
  2. Battery Percentage Indicator
    By mkhalil06 in forum Verizon Galaxy Nexus
    Last Post: 12-19-2011, 12:42 AM
  3. stock battery percentage indicator
    By vluc in forum Verizon Fascinate
    Last Post: 02-10-2011, 02:25 PM
  4. Battery Percentage
    By dman26 in forum HTC EVO 4G
    Last Post: 06-05-2010, 11:44 AM
  5. App For Battery Percentage to replace in notification bar?
    By surfacinglove in forum Verizon Droid Incredible
    Last Post: 05-11-2010, 10:46 AM
