Results 1 to 14 of 14
- 11-29-2012, 06:58 PM
Thread Author #1
Little Issues Making Me Wanna Throw the Phone - What Am I Doing Wrong?
Hi guys,
I have had the phone for four days now and I am coming from a Tbolt (running a 2700 mah extended battery, of course).
I am not familiar with this version of Sense, so please let me know if there is something I can do about these things that are starting to drive me bananas:
1.) App icons will duplicate and attach themselves to the homescreen after I have exited the app, even if there was already an icon on the homescreen to begin with. If I open the app twice, I would end up with three icons on the homescreen. How do stop this?
2.) Those same app icons that are putting themselves on the homescreen, simply because I opened the app, WILL NOT BUDGE once on the homescreen. To long-press on it does nothing - the "remove" and "edit" don't even appear at the top of the screen. The only way to get rid of it is to restart the phone, which I'm sure you can imagine will get old real quick.
3.) After restarting the phone, widgets do not reload at all, even after waiting about 20 minutes. I have to re-setup all the homescreens all over again.
4.) The internet/browser barely works - this happens whether I am using Wi-Fi at home (Lou, KY), on campus or using 4G. I keep getting the message that the webpage(s) has/have become unresponsive.
5.) Aside from problems with the internet (even at home), 4G also works only 10% of the time.
6.) I can't get the phone to stop vibrating for notifications.
7.) The battery - I have installed the same (not more) apps that were on my Tbolt. I have also installed the same Task Manager I had on my Tbolt and have set it to "auto-kill" pretty much everything. I have noticed that I can take the phone off of the charger with 100% battery life, go to school for four or five hours (where I keep both Wi-Fi and 4G off), look at the phone again and realize that I have only about 80% battery left. Is this a normal drain for a sleeping phone with a task manager and no internet connection?
8.) Is there a way to display the battery charge percentage on the lock screen when it is charging?
Am I missing something or have I gotten a "lemon"? Or, do I just need to have some patience while getting used to the new phone?
Thanks in advance! - 11-29-2012, 07:16 PM #2
Re: Little Issues Making Me Wanna Throw the Phone - What Am I Doing Wrong?
Sounds like you got a dud there - I haven't had anything even close to those kind of issues at all. I would bring it back to big red and show them exactly what you have and politely demand another phone. Good luck
Thanked by 2: - 11-29-2012, 07:23 PM #3
Agreed sounds like you have a lemon. I'd go get a new one. Competencies as far as the task manager I wouldn't install that. It might seem like it's helping but if it's constantly running in the background trying to shut down apps its definitely going to drain battery
- 11-29-2012, 08:20 PM #4
Do a factory reset first and see if it still happens, if it does take it back for an exchange.
- 11-29-2012, 09:06 PM #5
- 11-29-2012, 11:07 PM #6
Delete the task killer. That alone could be causing your system instability.
- 11-30-2012, 07:51 AM #7
- 11-30-2012, 08:31 AM #8
There is absolutely something wrong with your phone! What you describe is DEFINITELY not characteristic of the phone's behavior. If a reboot and reset to factory original condition does not take care of these issues, get a new phone pronto. Trust me, this phone is buttery smooth and has incredible battery life, particularly on standby. Yesterday I unplugged it at 7:50 AM and used it moderately all day, mostly on wifi then, on the way home I made about 45 minutes worth of phone calls over bluetooth in the car (still off any charger) and by the time I plugged it back in before I went to bed at around 11:00 PM it had 61% charge left!
- 11-30-2012, 08:43 AM #9
- 11-30-2012, 08:44 AM #10
- 11-30-2012, 11:09 AM #11
I would remove the task killer for one, then do a factory reset and start from scratch. If you are still having the same problem, take it back for an exchange; but it sounds more like a software issue than hardware.
- 11-30-2012, 02:07 PM #12
- 11-30-2012, 02:58 PM #13
- 12-01-2012, 11:23 AM #14
This is absolutely caused by the fact you have a task killer. I didn't know they even still had those in the market. Delete that, reset, move on and never, never ever ever ever, download a task killer again!
Droid X > Droid Bionic > Droid Razor > Galaxy Nexus > DROID DNA
What am I doing wrong with the camera?
By tekhna in forum Verizon Galaxy S3Replies: 29Last Post: 07-19-2012, 12:13 PM -
Local Sprint Corp store just emailed me to pickup the phone today
By foogle in forum Sprint Galaxy S II Epic 4G TouchReplies: 92Last Post: 09-15-2011, 04:54 PM -
MAkes me wonder if current phones are Ice Cream sandwich upgradable
By Oxn in forum Rumored DevicesReplies: 14Last Post: 08-05-2011, 03:29 PM -
Making Apps running on the Phone appear in a larger area on Webtop
By Shappy in forum AT&T ATRIXReplies: 0Last Post: 02-23-2011, 07:58 PM -
If Palm came out with a device equal in hardware to the Evo, what would you do?
By MannyZ28 in forum webOSReplies: 11Last Post: 04-18-2010, 08:17 PM
Reply
