Does this happen automatically? I want the phone to automatically switch to wifi when I'm near a zone and not use from my data plan. How do you set that up?
Printable View
If you just leave wifi on it'll connect to wifi hotspots that are saved and remembered. However, this can also drain battery because if you're out and about and the phone will constantly be trying to connect to unidentified networks.Quote:
Originally Posted by artakartel [Only registered and activated users can see links. Click Here To Register...]
Yes that's about it and it will drain it fast
Sent from my HTC One X+ using Android Central Forums
