Results 1 to 8 of 8
    artakartel's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Switching between wifi and 4G LTE...
    Does this happen automatically? I want the phone to automatically switch to wifi when I'm near a zone and not use from my data plan. How do you set that up?
  2. #2
    osubeavs728's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Switching between wifi and 4G LTE...
    Quote Originally Posted by artakartel View Post
    If you just leave wifi on it'll connect to wifi hotspots that are saved and remembered. However, this can also drain battery because if you're out and about and the phone will constantly be trying to connect to unidentified networks.
  3. #3
    cyanogen-man's Avatar
    Posts
    Global Posts
    1,049 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    ice cold sandwich aokp
    Yes that's about it and it will drain it fast
    Sent from my HTC One X+ using Android Central Forums
  4. #4
    Joan Bandy's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My phone is not automatically connecting to 4g when I'm out and leave wifi...it says "please check connections". Last night, i did finally get it working by going into data settings. I wonder if this has to do with battery saving app setup or something, but I'm still figuring that out, too. Often light is low and I need to be able to send and receive calls without a lot of tinkering.
  5. #5
    Dirtman16's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by osubeavs728 View Post
    The drain due to leaving on Wifi is typically overstated. I've never noticed a significant drop in battery life due to leaving Wifi on. You also risk forgetting to turn it back on and using up your allotted data (if you're on a tiered plan).
    streetstrip01 likes this.
  6. #6
    kaerophil's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    On the Samsung Galaxy S4, how do I switch between WiFi at home and 4G when I am not at home. What are the settings on the phone? I don't want the phone to be on 4G when at home, as it will use up too m uch of my data plan.
  7. #7
    KSDroid01's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by kaerophil View Post
    Not sure about the S4 but every phone I've had, once I leave my home WiFi range it would automatically switch to 4g...and back to WiFi once I'm back in range.
    Posted via the "Best Smartphone of 2013" One
  8. #8
    jec11718's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You should probably post this in the s4 forum....this is for the DNA...hey Mods, maybe move the post?
    sent from my Nos M7 DNA
  1. Signal, switching between 3G and 4G LTE
    By pauldroidr2d2 in forum Droid RAZR MAXX
    Last Post: 01-28-2015, 02:05 AM
  2. App to auto-switch between wifi and BT tethering?
    By TBacker in forum Android Apps
    Last Post: 06-18-2012, 08:30 PM
  3. Switching between Wifi and 4G
    By TmoodAndroid in forum Droid Bionic
    Last Post: 03-02-2012, 09:19 PM
  4. D-Inc Constantly Switching Between 3G and 1X
    By yotesfan499 in forum Verizon Droid Incredible
    Last Post: 08-11-2010, 04:50 PM
  5. Issues Going Between WiFi and Network
    By PookieEastwood in forum HTC EVO 4G
    Last Post: 07-20-2010, 11:00 PM
