Results 1 to 5 of 5
    PsychDoc's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Can Someone Explain The Difference Between The Data Setting Options?..
    IIRC there's LTE/CDMA, Global and GSM/UMTS. The default setting seems to be "Global." I thought GSM and "global" were basically synonymous but apparently not. And here in the US, why would Verizon have the default setting be "Global" rather than LTE?CDMA? And what is UMTS? Never even heard of that one. And why is it linked with GSM?
  2. Thread Author  Thread Author    #2
    PsychDoc's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Can Someone Explain The Difference Between The Data Setting Options?..
    Can anyone help here?
  3. #3
    osubeavs728's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
  4. #4
    jamdmyers's Avatar
    Posts
    Global Posts
    463 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    They promote the phone as a 'Global' Phone, hence I suspect they just leave the setting on mixed. It shouldn't have any issues with performance. I believe the UMTS is to assist in 3G contrary to what vZ thinks theyt really doesn't cover everywhere in LTE
  5. #5
    Markster1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Just set your phone to lte/cdma unless you travel overseas.
    Sent from my Verizon Note 2, finally!
  1. Replies: 19
    Last Post: 12-14-2012, 07:58 PM
  2. What's the difference between the 16gb and 32gb??
    By blueyzfr6 in forum Verizon Galaxy S3
    Last Post: 07-06-2012, 03:02 PM
  3. What's the difference between the new update and a aokp
    By thirsy1258 in forum Verizon Galaxy Nexus
    Last Post: 06-03-2012, 12:14 AM
  4. Replies: 3
    Last Post: 05-29-2011, 11:57 PM
  5. Anyone know the difference between the Coby 7005 and 7015?
    By Primetimeplaya in forum Misc. Android Tablets
    Last Post: 12-04-2010, 10:15 PM
