Results 1 to 23 of 23
- 12-01-2012, 11:12 AM
Thread Author #1
Streaming Battery Life.
I work for our local government in the city I live in and I have a big project coming up working on computers in a lot of new police cars. I am trying to find out how long the phone will last while streaming pandora. This will be an all day thing for about a month. So just wanted the music streamers out there to tell me the battery life they have been getting. Thanks.
- 12-01-2012, 04:00 PM #2
Re: Streaming Battery Life.
a little off topic, but couldn't you plug the charger in if the phone is in the car?
- 12-01-2012, 04:05 PM
Thread Author #3
Not really off topic if it is in the forum that pertains to my phone. I can't plug it in because I will be getting in and out of the cars.
Sent from my HTC6435LVW using Tapatalk 2 - 12-01-2012, 04:19 PM #4
would it be possible to do a wireless charge set up in the car? Still needs to put the phone down and pick it up when you are leaving the car but I guess it's better than plug in and unplug it each time? However I heard the wireless charging is much slower.
Back to your actual question...
I lose about 8-10% while I am out jogging, normally 5 miles run and takes me about 40 to 45 minutes, I use spotify to stream my music and it's connecting to 4g, my gps on with "Mapmyrun+" open to track my run, I also have 1 exchange email set to push and there are some other misc apps running sync.
When I am in the office, I use about 50% in 10 hours, that is with wifi on, emails, text, some quick phone call. - 12-01-2012, 05:32 PM #5
This could be dependent on multiple factors. Steaming something like pandora could drain a lot or little depending on your data service. If you have full 4G service you will see some noticeable drain but nothing so bad it will die in a matter of hours. That can't be said if you have low 4G service. An idea if battery life is a problem for you... download the app Phone Info or Device Info, can't remember the name off the top of my head and use that to disable the 4G radios so it will only stream on 3G and therefore draining less battery.
[GUIDE] Unlock Your Note 2 Bootloader! | [ROM] AOKP Jelly Bean for Verizon GS3
[GUIDE] VZW ROM Listing and Guide | [GUIDE] VZW Galaxy S3 Flashing Guide
[GUIDE]Freezing GS3 Bloat with Titanium Backup! | [GUIDE] Restore Back to Clean Factory Stock Updated 9/22
[GUIDE] [MODEMS] VZW SGS3 (SCH-i535) | [ROM] Official CM10 Nightlies on your GS3! - 12-01-2012, 05:37 PM #6
- 12-01-2012, 05:42 PM #7
Thread Author #8
I will try out several scenarios. I I am lucky that where I will be will have good wifi but not all that fast. I may be enough though to do some streaming. Also have very good 4G service here. Thanks it has been very informative.
Sent from my HTC6435LVW using Tapatalk 2 - 12-01-2012, 06:52 PM #9
Do you pay for Pandora One? If not, you might want to try Slacker. The subscription version allows you to cache stations.
Steve
Sent from my HTC6435LVW using Tapatalk 2 - 12-01-2012, 08:42 PM
Thread Author #10
- 12-01-2012, 09:07 PM #11
Even with some of the larger capacity phones from what you imply they may have issues as well, perhaps not as much as the DNA, a solution would be a battery pack you can plug in, they relatively cheap and are good insurance when charging isn't a option and you must have your phone,
- 12-01-2012, 09:23 PM #12
- 12-01-2012, 09:43 PM #13
- 12-01-2012, 10:01 PM
Thread Author #14
- 12-02-2012, 12:01 AM #15
The New Trent battery packs are pretty good. I picked up a 12000mah one from Amazon for about $50. That would be enough juice to charge your phone 6 times.
HTC Droid DNA Employee Edition 00960
HTC DNA
HTC Droid Incredible 4G - 12-02-2012, 12:20 PM #16
False. 30% of the charge in these battery packs is lost in conversion from the pack to the phone. So you'd get 4 charges while you carry around a brick.
- 12-02-2012, 12:51 PM #17
I have used slacker for about 4 hours a couple days in a row (not on wifi) and didn't see enough of a power drop to make me really check and see how much it really used. Coming from the Thunderbolt I am in love with the battery in the DNA.
- 12-02-2012, 02:25 PM
Thread Author #18
- 12-03-2012, 06:36 AM #19
- 12-03-2012, 07:37 AM
Thread Author #20
- 12-03-2012, 10:06 AM #21
- 12-03-2012, 11:40 AM #22
Just streaming data from 4g does not drain your battery faster than streaming from 3g, in fact it should be better on battery life because the radios are active for a shorter time since the songs are able to load faster. Its the constant searching for/switching from 3g to 4g that causes the most battery drain. If you're in an area with stable a stable network, your battery life shouldn't be too much worse than if you were streaming on wifi. Enjoy the speed of 4g when its available
- 12-03-2012, 02:38 PM
Thread Author #23
Battery life terrible?
By bilobi in forum T-Mobile G1Replies: 22Last Post: 06-12-2013, 07:45 PM -
Improving Battery Life on Your Android Device
By ERDude in forum HTC HeroReplies: 34Last Post: 06-06-2013, 08:57 AM -
Real world battery life streaming movies
By CRS1 in forum ASUS Transformer Pad Infinity 300Replies: 6Last Post: 07-30-2012, 10:18 PM -
Battery life: fm radio vs streaming
By bstmstrxellos in forum Verizon HTC ThunderboltReplies: 1Last Post: 04-05-2011, 09:11 PM -
Friend Stream and battery life
By GHB in forum HTC EVO Shift 4GReplies: 4Last Post: 01-23-2011, 07:56 AM
Reply
