12-07-2012 11:15 AM
32 12
tools
  1. PsYcHoNeWb's Avatar
    [WARN]These opinions reflect my personal use of this phone and do not represent those of Android Central. These are my opinions and my opinions only based on my experiences with this particular device. Yours may differ and that's what this all about.[/WARN]
    [INFO]Welcome to you DROID DNA.
    I want to start off my introducing myself, I am an adviser here on Android Central and since I have recently purchased a new DROID DNA you will see me around here often . I also have experience with the Galaxy Nexus, Galaxy S3 and RAZR MAXX/MAXX HD. I have been a long time Android enthusiast and smart phone junkie. I just wanted to post a little review of what I believe are the most crucial parts of this device and my opinion about them. Yours may differ and that's what this forum is about, intellectual discussions among users for the great good of the Android community both here on Android Central and all over.
    So what am I going to be reviewing here? Well like I stated before, I want to get into the most looked at parts of any smartphone now a days... Screen, Radios, Battery and much more. Buying a smartphone isn't so simple now a days since we have a lot of great choices out there and sometimes looking for 5 minutes in the store isn't enough to make a decision. Hopefully this will help because I will be updating this as issues come up or if I find something new and cool that you should be aware of.
    That being said, if anyone wants to chime in to add their 2 cents by all means please do. Also, if you want to see something added to the review parts speak up and I will most certainly do my best to provide you with the information you want.
    Now... lets get to the juicy stuff!
    If your lazy and don't want to read everything (I have done this too so don't feel bad ) there is a sum up at the end of this post.[/INFO]
    The Screen:
    It is obvious that this would be the first part of the review. It is the flagship feature of this phone and it damn well should be. 5-inch super LCD3, HD 1080p is nothing to take lightly. After owning many phones and playing with much more including the iPhone 5, Galaxy S3 and RAZR MAXX HD in the most recent bunch this screen BLOWS EVERYTHING AWAY. I really can't say it enough that this screen is simply gorgeous and of all the phones that I have used in the past nothing comes close. I have not had the opportunity to look or play with the Galaxy Note 2 yet, but I don't see how the screen would be able to get much better than this.
    There have been reports of people saying they are getting screen distortions when too much pressure is applied to a particular part of the screen but I have not experienced this myself. Some have reported that it is due to a case that Verizon sells so for now I would say stay away from Verizon cases, personally I have never liked them anyway but I would look else where for a case. If you do see certain screen distortions, GO TO VERIZON RIGHT AWAY. This is flagship feature and sell point of the phone and if you are experiencing issues you deserve a working model.
    Edit:One of our users reported that this isn't so much a case problem but more a gorilla glass problem. Applying too much pressure on the same parts of the screen could cause distortion to the screen so keep that in mind. Be careful with your device, this is a very expensive piece of hardware so just be careful and think about what you are going to do it with. If you can avoid applying excess pressure, wether it be using it normally or putting it in you pocket just be mindful of this.
    Aside from the one issue mentioned which might not (I said might ) be a huge issue if you don't use cases the screen is on the top of the list. This will be the benchmark. Period.
    Performance:
    Qualcomm APQ8064 Quad-core 1.5 GHz CPU. Does there need to be much more said here? Its fast. The only feature that I have notice that slightly laggs the phone is the display and many other reviews have said this as well but the lag is so minimal in almost all the cases I have seen that it isn't even an issue. I have used this now for 3 days and it has been a speed demon. Everything I threw at this phone runs amazingly smooth and haven't experienced a hiccup in speed yet. Like I said before, you might see a little bit of lag on the screen but you have to remember here the CPU is trying to process a 1080p screen, not an easy task. For the basic applications like email, texting, social networking, browsing and the occasional game, this CPU will eat it up and laugh in your face when you think it might slow down.
    I personally believe that Quad Core CPUs are going to become the standard for all flagship phones from here on out and if a new one doesn't have one, they are behind the times. This phone is a prime example as to why the new generation of smartphones need a quad core processor. You can't run a 5" 1080p screen on a dual-core CPU and expect it to run smooth. That is just not going to be possible. While this is where I would put benchmarks or speed tests, I don't believe that they are a true representation of real world use. If you want to run, by all means do so and report back here but this bad boy has everything you need and then some for real world uses.
    Cell Service and Radios:
    This is a catagory that has been under much scrutiny over the past months or so, especially with the expansion of Verizon's 4G LTE network. I know that my area has only had full 4G service for 1-2 months now and its great. When I had my Galaxy Nexus, the radios where horrible. Probably one of the worst features on the phone and the reason that many people hated that phone. Luckily for me, they didn't present any problem but looking back I see now how bad they are. The RAZR MAXX HD had some of the best cell radios I have used in an LTE phone. Never lost data, never had issues between 4G and 3G and rarely had a handoff issue. So how does the DNA stack up?....
    Extremely well. Handoffs between 3G and 4G have been quick and painless, 4G receptions has been stellar and I have not had one issue of data dropping. *knocks on wood*. If you have been worried about cell phone service because of work, family or whatever it may be you can rest assured that this will work great for you. I can't speak for everyone, but I have not had one issue with cellular or data service in my area (tri-state area).
    Edits:This phone does not support simultaneous data and voice. If this is an important feature to you, look else ware... mainly the RAZR HD or MAXX HD. The other thing worth mentioning that I experienced earlier today, in an area where I had very low 4G service the DNA will go back to using the 3G radio. My MAXX HD would get basically 1 bar for 4G service in certain areas but now the DNA reverts back to 3G.
    Phone Call/Voice Quality:
    Currently I have not experienced one issue with the quality of the phone. Crisp and clear calls with a good amount of volume. Making phone calls via the handset or using my car's bluetooth system and I can't report any glaring issues that would give a huge negative mark here. Calls connect quick, no issues on the other end of the call that anyone has told me. Everything has been up to par here. One issue that I can report is the in call volume on the handset could be a little higher. I have mine all the way up and while its good enough most of the time, I find myself thinking that if I am in an area with a lot of background noise I would wish it would be able to go louder. That could be because I am going def but still an area for concern if you find yourself wanting the ability to have loud in call volume when using the phone itself.
    Battery Life:
    I am sure that this is on the that most people are looking forward too. These parts aren't as easy to review because everyone's use is different and everyone's phone is different depending on when they where manufactured, what apps installed, what accounts are syncing and many more. Because there are so many variables that can determine your battery life it is almost impossible for me to tell you what you can expect. However, I can tell you what my results have been based on what I use my phone for on a daily basis.
    I take my phone off the charger around 7am give or take and it is connected to my home WiFi until I leave my house around 7:35-7:45am. Once I am on the road I am connected to my cars bluetooth and usually keep 4G service through most of my drive, maybe hitting one spot that it drops to 3G. Arrive at work around 8:30 and connect to my office WiFi and from there I don't use my phone all that much. Occasionally checking and responding to texts and emails. Basically the time I am at work its light to moderate use. Once I leave work around 5-5:30 the use of my phone is moderate use and connects to WiFi if I can or just leave it on 4G. Texting, checking emails, facebook, twitter, tapatalk, G+ and some GTalk. By the time I get to the point its beeping at me at 14% to plug in its around 11:00pm-12:00am depending on usage through the day.
    Based on those figures there, I am very happy with the battery life. Yes its not the best, but what do you expect from a phone with a 5" 1080p Quad Core phone? I have impressed that it lasts as long as it does. I am sure that if you use the screen more than I do you will see less favorable results but again you have to take into account the screen you are using. It will eat your battery and looking at the screen you will be happy you are. If battery life is a huge concern for you, I would invest in a car charger or get a Qi Charger since this has wireless charging built in.
    Again, this is all dependent on your usage. I would say that if you use your phone moderately through the day you can make it a full day until you get home but when you do you will need to charge it up. Now I know some say its bad to do, but I leave my phone plugged in overnight while I am sleeping. Just the easiest way for me and by doing this I don't have to worry about charging a phone mid-day unless I use my phone a lot.
    Bottom line, I am happy with the battery life especially taking into account the specs and performance of this phone.
    Build Quality and Feel:
    HTC has always built some of the nicest looking and quality to hold phones, at least to me. Yes, the Thunderbolt was a brick to hold and a monster but there was no denying that it felt like a solid and expensive piece of equipment. Most recently the HTC One series has been some of the nicest looking phones out there and this take a page right out of their books. While the Black/Red color scheme may be getting a little old there is no denying that it is a beautiful phone. Light, thin, sleek and modern looking. Doesn't have too much "dead space" on the front and very simple looking on the back. The buttons on the bottom (back, home and recents) are small so they don't take up too much real estate but they are sizable enough to feel natural to hit.
    There are 2 problems here, but one of them is known to you when bought...
    The first one is the size. It is a 5" phone so if you have smaller hands then this might feel awkward to hold at first. Myself, I am use to larger phones like the MAXX HD and GS3 so this wasn't much different and came naturally for me to hold. The soft matte finish on the back feels great in the hand and even though its light to hold it still feels expensive and that is a result of the build quality. It doesn't have too much cheap plastic like the GS3 and it doesn't have the gimmicky carbon fiber backing of the MAXX HD. It hits that happy medium between the two, nice to hold because of the external materials but not to heavy to hold.
    The second issue that I foresee being an issue is the power button. Being right in the middle it sometimes is pain to click. Myself, I have attempted to click it multiple times but have to adjust my grip to fully click down on the button to wake the phone. While this is something that will take some getting use to, it makes me wonder why HTC put it in the center when they could have easily put it on the side like every other phone out on the market now. I am sure there are reasoning behind it, but a little more thought by HTC on this might have made the build of the phone an out the park home run.
    As is right now, its an upper deck home run.
    HTC Keyboard:
    This is probably one of the best manufactured built in keyboards. I has tracing, decent predictions and pretty good response. I hated the GS3 stock keyboard and the MAXX HD stock keyboard was just a basic ICS one which isn't bad but nothing special. Overall this is a great keyboard for veteran smartphone users or new timers alike. It will take a little getting use to for the size of the phone and differences between different keyboards but I have found myself continually using this keyboard instead of switching to my standard, Swiftkey 3. I am waiting for Swiftkey Flow, but until then I am perfectly happy with the HTC Keyboard, I would say it is one best if not the best stock keyboards. One issue that I find with this keyboard that I wish they added is a way to change the vibrate intensity. I would increase it slightly, doesn't seem to vibrate enough but this could be personal preference.
    That being said, I am not including the stock 4.2 Jelly Bean keyboard which is my overall favorite right now. I do plan to install it once I get bored with the stock keyboard if I ever do but the HTC Keyboard is a quality typing experience.
    HTC Sense:
    I will be the first one to tell you that I am stock AOSP fan boy. I love the stock look of Android, especially ICS/Jelly Bean. That being said I will try to remove my bias from this. Sense isn't all that bad when you get down to it. I really do like the tweaks that HTC has done and the widgets they offer are some of the best you will find on a stock launcher. The launcher itself doesn't lag like the MAXX HD Blur launcher does which is a HUGE plus for me. The menus are all tweaked to make them look different the stock AOSP but they are nicely laid out and color schemes are very easy to get use to. Obviously this will all come down to personal preference, but I would say that out of the big names in stock layouts HTC has one of the best. This is how I would lay it out right now, excluding stock AOSP...
    HTC Sense > TouchWiz > Blur
    That being said, if you are like me and AOSP fan boy this will take some getting use to but I found myself liking Sense quicker than TouchWiz and Blur. Even though Blur is pretty close to AOSP it lags which is a huge negative. I have not experienced one hiccup with Sense and it looks the best out of all of them. Features all seem to be the in that you would expect and its very easy to navigate the menus. Also, HTC was thoughtful to include personalization options to change the theme and lockscreens. They offer a good amount of options so that you can make it your own. You can also personalize the SMS app to change color schemes, font sizes and backgrounds. It is just a nice touch added to the phone that wouldn't be considered necessary.
    [TIP]Some have found the font size in the SMS app to be rather large when in a thread. Even if you set the text to small in both the SMS app and general settings it still is relatively large. It has been found that if you pinch-to-zoom you can change the size as if you where zooming in and out of a webpage it works the same way in the SMS app threads. Works great to make the font smaller and much nicer to view. Do it in one thread and it stays for all text message threads.[/TIP]
    Camera:
    I am coming from the MAXX HD camera so this is a clear cut review. Its damn amazing. While it may not have as many features as the GS3 camera, the quality of photos are stunning. I have not used the video recorder yet but I don't see how it could be bad based on the camera. Pictures are not fuzzy at all unless you zoom in, camera snaps picture very quick and the auto-focus is quick as well. I have a feeling that I will be using my phone camera a lot more than I did in the past.
    Memory:
    Here is one of my biggest cons... no SD card and only 16gb internal memory which only comes out to around 11-12gb once it is formatted. Granted, that can hold a good amount of stuff but you would think that flagship phones now a days would either have an SD card slot or AT LEAST 32gb internal memory. If you use a lot of storage on you phone for music, pics or videos this may become a problem.
    Verdict and Sum Up:
    So whats my verdict? Well if it isn't obvious by now, I would easily recommend this phone to someone looking for the next generation of not just smartphones but what could be considered superphones. While the phone has some negative marks against it, the DROID DNA is possibly one of the best phones out on the market right now. Needless to say it is the best model of the Verizon DROID line and may be on the top phone Verizon offers. With the price tag of $199 its pretty hard to beat.
    Pros:
    • Amazingly Epic Screen
    • Great Performance
    • Solid Build Quality
    • Great Camera
    • Good Radios/Call Quality
    • HTC Sense Personalizations
    • Stock HTC Keyboard
    Neutral:
    • Battery Life
    • Call Sound Could be Higher
    • Power Button Placement
    • Color Scheme Getting Stale
    • Size Could Be Awkward to Hold
    Cons:
    • Verizon Bloat
    • No SD Card and Only 16gb Internal Memory
    [INFO]Review Parts to Come:
    • Speaker Quality
    • Headphone Music Quality
    • HTC Sense Stock Applications
    [/INFO]
    [NOTE]If you want to see something added to this review, please let me know and I will be more than happy to do some testing. Also, if you disagree with me about something speak up. This is all about personal preference and if you don't agree with what I am saying then someone else might not and it could help influence what someone will buy. Again, I am doing this review to help those are are on the fence about this phone. I love this device except for its couple flaws which are minor in my opinion but you may view them as huge issues.[/NOTE]
    12-01-2012 11:20 AM
  2. zero neck's Avatar
    awesome review crecca. if for some reason i end up staying with verizon, ima try to find a way to get this off contract. thanks for sharing
    PsYcHoNeWb likes this.
    12-01-2012 11:40 AM
  3. dsignori's Avatar
    Thanks for he review. I concur with just about all of your points
    12-01-2012 01:06 PM
  4. chickweedblur's Avatar
    A very nice write-up! I agree as well for the most part. I am new to Android having been drinking apple cider since the 3Gs. I had a GS3 the last month at AT&T before moving to Verizon.
    I really like the flexibility Android offers. I've had this phone for a few days now and think I will keep it and sell my iPhone5. I've only taken a few shots but I think the camera is fantastic. Easily better than my iPhone indoors. Very natural looking results and good color balance.
    My only hesitations are:
    1. Size. It's big. No way around it. The GS3 was really plastic but light. I didn't notice it at all in my pocket. There's no getting around it with the DNA. Dress pants, jeans, cargo shorts - it's like a small book in your pocket. I think it's the weight. I can live with it, but it will take some getting used to.
    2. The screen, while amazing, it somewhat wasted. Not HTC's fault but there's little in the OS or Sense that takes advantage of it. Sure you can show off a high-res Youtube video and get alot of "oohs" and "ahhs" but you still can't display more than 6-7 emails at a time using the stock email client or as you said, the messaging app. The stock calendar must have been written for a 320x240 phone since the month view has no information on it. The icons and widgets are so spread out it's silly. I've loaded Nova and Apex to test and a launcher goes a long way to fixing this but being a newb it's a time consuming process to get it just like you want it.
    Also - I have the Diztronic Black TPU case and while you lose the nice taper at the edges the stock phone has, if you want/need a case it is hands down the best $12.50 case I've ever seen. It's worth 2x that really.
    12-01-2012 01:59 PM
  5. PsYcHoNeWb's Avatar
    I agree to an extent with your comment about the screen and a lot of unused space. While it does appear that there is a lot of unused space that is a by-product of having a 5" screen phone. It just looks like there is just too much screen for the stock applications but when you start playing games or looking at videos/pictures online the screen size really comes in to its own. It does take a while to get use to since it is big but if you can get use to the screen size what a screen it is.
    12-01-2012 02:48 PM
  6. TriangleZ's Avatar
    Nice review there, pretty much how I feel about this phone. I came from the original Incredible so this was a definite step up for me.
    I was one of those people who may have damaged the screen by applying too much pressure. Maybe you read my post? I don't think it's much of the case/holsters fault, I just thought the DNA with it's gorilla glass, was able to take some pressure while I grab the phone from the holster. The way the holster is a sliding style and with a 5" display, it takes awhile to slide the entire phone out, and with the added tightness from the holster, a couple times I had to grab the phone from the screen so that was completely my fault if I did damage it. I thought it was built like a tank like the original Incredible, I dropped that thing a couple times and it's still alive. Now, I am much more careful handling the phone with the display at all times.
    12-01-2012 03:32 PM
  7. linebusy's Avatar
    Could be mentioned in the radio discussion that it lacks simultaneous voice/data on 3g. Thanks for the write-up! Your comments on the Maxx HD radio has convinced me to go get one. I know the idea is to have 4g everywhere at some point this year, but it's reasonable to think rural users are still far, far away from seeing their areas fully covered.
    12-01-2012 04:08 PM
  8. zero neck's Avatar
    bezel is pretty slim tho, right?
    12-01-2012 04:54 PM
  9. jfoofoo's Avatar
    yup!
    zero neck likes this.
    12-01-2012 04:59 PM
  10. PsYcHoNeWb's Avatar
    I read through it quickly but I will make sure that the review reflects this. Appreciate your input!
    There is no arguing that the Motorola puts out some of the best radios and the HD and MAXX HD is no exception. If that is your main concern I don't blame you in the least.
    Also on the simultaneous voice and date, good point I completely forgot about that... good call!
    Yea very slim. Almost all screen real estate.
    12-01-2012 05:24 PM
  11. linebusy's Avatar
    For clarity sake:
    The limitation it has is on 3g only. 4g and wifi support simultaneous voice/data, 3g does not.
    12-01-2012 08:48 PM
  12. jamdmyers's Avatar
    Two Items from the discussion, vZ plans are to be nationwide lte by EOY 2013, we'll see but it make sense to drop off thier support for 3g.
    The other is the 'extra screen space' One reason I purchased this phone was for future expansion, I read many forums where people jump from phone to phone, I'm not one I pick a phone that has the gas tank to take me through the next two years. I suspect there will be many apps and uses for this screen as time goes by and developers leverage it's capabilities, at least I made a $199 bet they would.
    12-01-2012 09:04 PM
  13. SugarMouth's Avatar
    *** Business Calendar! Love it!!!
    12-01-2012 10:06 PM
  14. Susan E's Avatar
    Hello. I want to say that I got the Droid DNA yesterday after trading in the iPhone 5 and this phone cannot be beat by anyone, anywhere! It is AMAZING! With the regard to the cons of the volume rocker and power button, I added an Otter box and voila! The volume buttons and the power button is raised up, so no more issues. Thank you for the insightful review. I couldn't agree more that this is the phone to beat!
    12-02-2012 09:52 AM
  15. sicario666's Avatar
    Once again. Thanks for the review. I turned off the lazybones mode and read the entire review. Word for word. I'm looking to buy my wife a new device so this helped me on my decision. She has considerably smaller hands so the DNA and the note2 will both be larger for her. She has a nexus now but wants a larger display. Its pretty much down to her deciding which one is better for her. But its always good to have the edge of explaining what device has what features.
    Sent from my DROID RAZR HD
    12-02-2012 03:06 PM
  16. PsYcHoNeWb's Avatar
    Could always give her your RAZR and get the DNA for yourself
    sicario666 likes this.
    12-02-2012 03:48 PM
  17. sicario666's Avatar
    True. She despises Motorola devices though. I took her into a Verizon yesterday. She asked me what phone she can get that she won't have to add an extended battery to. I told her...maxx or maxx HD. RAZR M but that's kind of a step down. I've been hogging up all the upgrades as of late. Its time for her to get what she wants. Plus. I use my phone for my music too. 16gigs just isn't enough for me.
    12-02-2012 04:11 PM
  18. PsYcHoNeWb's Avatar
    Yea if you need more than the internal memory on this device then I really can't recommend it whole heartily. I love the phone don't get me wrong but it does have some noticeable chinks in its armor. If she wants a smaller phone that she doesn't need to swap batteries out constantly the only ones on Verizon I could say would be the MAXX/MAXX HD like you said.
    I actually was in the Apple store today to help someone by a Macbook Pro and the guy at apple was trying to convince me to look at an iPhone 5 and when I showed him my DNA he was amazed at how insanely big it is compared to the iPhone 5 and I was holding the iPhone 5 and it feels just too tiny and puny lol. I love the compact feel of the iPhone 5 and there is no denying that when it comes to designing a phone Apple has a tried and true recipe that will sell but I think they made a huge misstep by not making the screen bigger. Just making it longer was a huge mistake, especially considering the trend of smartphones. I considered going back to an iPhone since for work it would be easier to set everything up but I know myself, I would get bored with it within hours and hate it and waste the money to return it.
    12-02-2012 04:19 PM
  19. Megaroad's Avatar
    Blur >>>> Sense. Blur is very good right now. It's basically stock + improvements.
    As for lag...the DNA shipped with Jelly Bean. Maxx HD doesn't have it yet. Should smooth it out.
    12-02-2012 04:24 PM
  20. sicario666's Avatar
    When the i5 released. I HAD to get one. Had it for about a week. Then sold it. Got the M. Sold it...got a maxx. Then got the maxx HD. The i5 is a nice piece of hardware. But iOS just got boring to me. I'll stick to android. And yes. Apple did fumble when it came to design in terms of keeping up with the competition. The DNA is a larger,faster machine. Better display. Memory wise its just a match of a 16gig i5.
    I'll have to say...development for the maxx HD. Its been a serious flop. Which doesn't hinder my decisions about the hardware. I'm sure the DNA dev scene will be much larger.
    12-02-2012 04:47 PM
  21. PsYcHoNeWb's Avatar
    I had Jelly Bean on the MAXX HD. Very laggy still. Reason that I hate blur is because it's close to AOSP and ruins it with lag and other cluttered features. If you want to make it look AOSP make it AOSP.
    Sent from my HTC6435LVW using Tapatalk 2
    12-02-2012 05:30 PM
  22. SEAL62505's Avatar
    This thread was extremely helpful. Right now iOS is boring to me. Trying to decide between WP8 or the DNA. DNA scared me at first because so many screamed about battery.
    12-02-2012 10:22 PM
  23. PsYcHoNeWb's Avatar
    This was the case for me. I came from a Droid RAZR MAXX HD which has the best battery life so it was a hit in that category. I would never go back to an iOS device and if I did it would be for 2 days then I would be bored. W8 intrigued me since I have it on my desktop and its not bad, would be much better for a touch screen which is why I considered the HTC W8x. That being said, I am an Droid guy all the way and only one thing would come from me buying anything else... a $35 restocking fee.
    12-03-2012 06:16 AM
  24. Megaroad's Avatar
    Even with ICS the Maxx HD is not "very laggy." And clearly you didn't have it with the final version of JB for it, hence it not being released.
    12-03-2012 03:54 PM
  25. PsYcHoNeWb's Avatar
    For me, it was graphically laggy which is a huge con for me. Could have been the OS or the hardware, who knows but I know for sure that after testing it and using other phones such as the GS3, Nexus and now the DNA the MAXX HD had noticable lag compared to others. Most noticably when opening folders on the home screens. You may not experience the same lag because of homescreen layouts and what not, I don't know for sure but I had unacceptable graphical lag.
    In regards to the OS, that may be the case but the leaked version I flashed was pretty close to a release version, basically the same that was running on the Droid RAZR M. Basically the same phone, just smaller screen. I would not be shocked if the released version will have the same issues, Verizon is more concerned with making it sure complies with their "enhancements" more than usability.
    Believe me, I am not saying your wrong in anyway. I may have had an internal issue with the phone but I had multiple people who are also Droid enthusiasts look at my phone and they agree that there was certain points that the phone lagged when it shouldn't. It was a great phone, but I think Motorola had a major mistep by not releasing the phone with Jelly Bean. Also, they released a dual core phone when multiple devices (DNA and Note 2) are coming out with quad core CPUs. Yes, that would impact the battery life but with the huge battery in the MAXX HD it would have been a perfect match.
    12-04-2012 07:55 AM
32 12
  1. Iphone4 vs Droid incredible review. I have both.
    By logan78511 in forum Verizon Droid Incredible
    Last Post: 09-23-2010, 12:06 PM
  2. Droid X Review up at Anandtech
    By judasmachine in forum Motorola Droid X
    Last Post: 07-23-2010, 10:08 PM
  3. Replies: 1
    Last Post: 07-19-2010, 11:34 AM
  4. DROID X Review - Extremely Detailed!
    By BlakeDC in forum Motorola Droid X
    Last Post: 07-16-2010, 04:10 PM
  5. PRE vs DROID (honest review from Pre user)
    By ali.fazal in forum Other OS's and Devices
    Last Post: 12-26-2009, 10:57 AM
