Results 1 to 4 of 4
- 12-02-2012, 11:33 AM
Thread Author #1
Bluetooth Headsets - Which Ones Work with the DNA, and Which Ones Don't?
One of my very few disappointments with the DNA is that my old headset - Plantronics 510 Voyager - will not accurately make voice-dialed calls. It called flawlessly on my Incredible, but appears to select random contacts when used with the DNA - seriously, three consecutive tries get three different, wrong results. Curiously, it works perfectly for manual|speed-dialed calls and also for dictated texts, shopping lists and everything else. I tried the "mic" icon when using the phone with BT disconnected and the DNA recognizes that perfectly, "call line 2 at home" produces that exact text string in the number box (of course it won't call there, but it shows that I have not suddenly lost my ability to speak clearly). I tried a newly-purchased Plantronics M50. Same result. HTC responded promptly to my query and said that there is no standard for BT dialling, so everybody builds their own bluetooth stack. That is, HTC uses a different BT stack in the DNA from that used in the Incredible. I could go buy one of each, but I am hoping that other dedicated voice dialers out there have had similar experiences, so:
Please Reply with the Make and Model of your BT headset and indicate whether it works or does not work accurately for voice-dialing. Thanks! - 12-02-2012, 12:49 PM #2
Re: Bluetooth Headsets - Which Ones Work with the DNA, and Which Ones Don't?
I have a Plantronics Marque 2. The sound quality it good as any other headset that I've had. No problems streaming music, crisp calls. It does not have voice dialing though, only voice answering which is weird but whatever. Maybe once the app is updated to support the phone it'll add voice dialing.
- 12-02-2012, 04:02 PM #3
- 12-03-2012, 08:09 AM #4
You aren't going crazy. I believe the problem is actually Jellybean.
On the galaxy nexus, the jellybean update caused problems with Bluetooth voice dialing. It seems to be tied into Google now. The latest JB update from Google (4.2) actually switched BT stacks completely, and made it a little bit better.
Maybe we will get an update in a few months, but in the meantime galaxy nexus users have been using an alternative voice dialer with some success.
I must admit that as much as I live android, that android, Bluetooth, and voice dialing. leave something to be desired.
My old windows phone had much better Bluetooth dialing than my old droid incredible, and especially better than my galaxy nexus, and my DNA.
Sent from my HTC6435LVW using Tapatalk 2
Which ROM works with the activation.apk??
By eliment in forum Optimus V Rooting, ROMs, and HacksReplies: 7Last Post: 06-02-2012, 04:05 AM -
Which portable battery charger works with the Rezound?
By PaulQ in forum Verizon HTC RezoundReplies: 1Last Post: 01-14-2012, 02:15 AM -
Will this battery work with the Evo and the battery door sold with sprint ext. batt?
By tailsthecat in forum EVO AccessoriesReplies: 4Last Post: 07-26-2011, 10:36 PM -
Does this headset work with the Atrix? MEElectronics M6P-BK
By NYGiants84 in forum Atrix AccessoriesReplies: 0Last Post: 05-11-2011, 06:12 PM -
So..... Which cases work with the OEM docks?
By Bob Brown in forum AT&T ATRIXReplies: 21Last Post: 03-01-2011, 12:54 PM
Reply
