Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 84
Like Tree30Likes
  1. #51
    bellken's Avatar
    Posts
    Global Posts
    311 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: I'm sorry, but the battery life on this device is atrocious.
    Another thought, Fastboot is enabled by default. You can try disabling fastboot, as, some apps don't play nice with fastboot.
  2. #52
    dammitcubs's Avatar
    Posts
    Global Posts
    280 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    dude the battery life is amazing.
    I have instagram, Facebook, twitter and all other services on. My battery life at work lasted 12 hours and then when i got home I was looking for wallpaper the entire time while watching the Giants vs Redskins game. The standby time is also amazing. I haven't been happier. If this batter was 2500, it would be even more amazing
  3. #53
    Gekko's Avatar
    Banned
    Posts
    Global Posts
    8,236 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i suffer no hardships doing this -
    Battery Tips for Android
    1. Toggle off LTE, WIFI, GPS, BT, NFC, Hotspot. Toggle on as needed.
    2. Display Brightness - Turn off Auto Brightness and Reduce Setting Bar to Minimum.
    3. Sign out of Google Latitude, GTalk, G+, Google Now, and Messenger. Disable Location Reporting/History.
    4. Beware of constantly syncing Apps and Bloatware like Facebook, Twitter, News, Non-Push Email, etc. Set Sync interval for every 1 hour or more.
    5. Turn off keyboard haptic feedback.
    6. Don't use Live Wallpaper. Use dark wallpaper if possible.
    7. Set Display Sleep Setting to 2 Minutes or Less.
    8. Set WIFI to Always stay on during Sleep if you regularly use WIFI.
    9. Turn off vibrate for Emails.
    10. Be careful of using too many live widgets.
    11. Sync Exchange Emails 30 Days or less.
    12. Do NOT use a Task Killer App.
  4. #54
    PureEnergi's Avatar
    Posts
    Global Posts
    13 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    you can also set the background process limit. seems to work for me i have absolutely no problem lasting the day and i am a heavy web/email user. if i use it lightly it will easily last a day and a half.
  5. #55
    hannsoft's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Gekko View Post
    Great tips, all, with the lone exception being the fact that we can't turn off LTE on the DNA..
    Sent from my HTC Droid DNA via Tapatalk 2
  6. #56
    varucell's Avatar
    Posts
    Global Posts
    195 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by PureEnergi View Post
    How can you do this. That sound like a great idea.
  7. #57
    dsignori's Avatar
    Posts
    Global Posts
    1,706 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I don't do ANY of that, and suffer no hardships.
  8. #58
    mclarryjr's Avatar
    Retired Moderator
    Posts
    Global Posts
    6,549 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    NOS M7 Sense 5.0
    Quote Originally Posted by dsignori View Post
    Same here this is by far the best battery life I've seen from any Android device I've owned.
    Droid>Droid 3>Dinc>Thunderbolt>Gnex
  9. #59
    phonenut's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by schwinn123 View Post
    Here is my graph, any thoughts?
    my thoughts are that you're a very good diagram man
  10. #60
    oscarnyc's Avatar
    Posts
    Global Posts
    300 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mclarryjr View Post
    you seem to have hit the tri-fecta of crappy battery life devices the the Dinc, T-bolt and Gnex. everything is relative.
    mclarryjr likes this.
  11. #61
    scorpiodsu's Avatar
    Posts
    Global Posts
    5,147 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by varucell View Post
    Settings > Developer Options.
  12. #62
    Danny Fernandez's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    What did you set your background proccess limit to? This didnt affect your phone negatively in anyway?
  13. #63
    Sooks's Avatar
    Posts
    Global Posts
    5,185 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Not sure if anyone has posted this yet, but the camera issue you are having is a "feature" of the phone, if you leave the camera app running then power off the screen or if you open the camera and not exit the application it will continue to run which is why you are seeing 22% of your battery going to camera. Its a "never miss a picture" feature. Try killing the camera with the app switcher ( not a task killer as they will actually cause more harm then good)
    mclarryjr and swenpro like this.
  14. #64
    jrz5024's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    ACS SyndicateROM Frozen
    Quote Originally Posted by hannsoft View Post
    There is a stock widget you can use to disable data.
  15. #65
    jrz5024's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Great tips overall. I just wanted to note that while using a dark wallpaper on SAMOLED screens saves battery (as it turns off those individual black pixels), it won't do anything for LCD displays like on the DNA, which are backlit.
  16. #66
    heath patrick's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    12 Hrs. on battery with 7 Hrs. of streaming music through Google play music,screen on for close to 2 hrs & Wifi on the entire time. Battery now at 37%
  17. #67
    splmonster's Avatar
    Posts
    Global Posts
    1,447 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Changes weekly!
    Great points indeed! Only disagreement I have is some of the Google services. At least in my testing Gtalk, G+ and Google Now all used very little battery life across many of my devices. I also typically leave NFC on and it's completely dormant during non-use. Don't see it being a problem either.
  18. #68
    hannsoft's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by heath patrick View Post
    http://i199.photobucket.com/albums/a...5-23-46-17.png
    Hey folks, how are all of you getting these screenshots??
  19. #69
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hold power and volume down buttons at the same time for a couple seconds.
  20. #70
    PureEnergi's Avatar
    Posts
    Global Posts
    13 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by Danny Fernandez View Post
    I set mine to 4. I set it to 4 on my gs3 also. Seems to work well. No adverse effects. Beats having 20-30 processes cooking in the background
  21. #71
    aallison1882's Avatar
    Posts
    Global Posts
    141 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The power button and volume down does not work for me. Only the power button and home screen button does.
  22. #72
    mightyfacundo's Avatar
    Posts
    Global Posts
    1,623 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by aallison1882 View Post
    It's good to see that some things about HTC don't change. This is how it is with the Thunderbolt. Some phones use the power button and home button to take a screen shot, while others, like mine, use the power button and volume down. I'd love to know why it's different.
    Sent from my ADR6400L using Android Central Forums
  23. #73
    bellken's Avatar
    Posts
    Global Posts
    311 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This is what works for me, too.
  24. #74
    Sooks's Avatar
    Posts
    Global Posts
    5,185 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You have to click the power and volume down at the same time and hold for 2 sec. However, this power and home is easy as well, thanks for sharing that!
  25. #75
    dsignori's Avatar
    Posts
    Global Posts
    1,706 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Sooks View Post
    The both work, however the Power + Home Button method does not show the saved screenshot in the notification area, nor does it allow for quick sharing of it. The Power + Volume Down method does, so I prefer that way.
  1. How is the battery life on the skyrocket?
    By Lavitapostandroid in forum Samsung Galaxy S II Skyrocket
    Last Post: 06-19-2012, 03:13 AM
  2. Is the battery life really this bad?
    By joe_sun in forum Verizon Galaxy Nexus
    Last Post: 03-28-2012, 10:50 AM
  3. All this crying on the battery life on the first true 4G mobile
    By Chilly818 in forum Thunderbolt Accessories
    Last Post: 04-04-2011, 01:59 PM
  4. All this crying on the battery life on the first true 4G mobile
    By Chilly818 in forum Verizon HTC Thunderbolt
    Last Post: 04-04-2011, 12:13 PM
  5. What's the battery life on this?
    By sekser in forum Google / HTC Nexus One
    Last Post: 03-15-2010, 05:36 AM
