12-08-2012 04:18 PM
84 1234
tools
  1. bellken's Avatar
    Another thought, Fastboot is enabled by default. You can try disabling fastboot, as, some apps don't play nice with fastboot.
    12-03-2012 09:24 PM
  2. dammitcubs's Avatar
    dude the battery life is amazing.
    I have instagram, Facebook, twitter and all other services on. My battery life at work lasted 12 hours and then when i got home I was looking for wallpaper the entire time while watching the Giants vs Redskins game. The standby time is also amazing. I haven't been happier. If this batter was 2500, it would be even more amazing
    12-03-2012 09:39 PM
  3. Gekko's Avatar
    i suffer no hardships doing this -
    Battery Tips for Android
    1. Toggle off LTE, WIFI, GPS, BT, NFC, Hotspot. Toggle on as needed.
    2. Display Brightness - Turn off Auto Brightness and Reduce Setting Bar to Minimum.
    3. Sign out of Google Latitude, GTalk, G+, Google Now, and Messenger. Disable Location Reporting/History.
    4. Beware of constantly syncing Apps and Bloatware like Facebook, Twitter, News, Non-Push Email, etc. Set Sync interval for every 1 hour or more.
    5. Turn off keyboard haptic feedback.
    6. Don't use Live Wallpaper. Use dark wallpaper if possible.
    7. Set Display Sleep Setting to 2 Minutes or Less.
    8. Set WIFI to Always stay on during Sleep if you regularly use WIFI.
    9. Turn off vibrate for Emails.
    10. Be careful of using too many live widgets.
    11. Sync Exchange Emails 30 Days or less.
    12. Do NOT use a Task Killer App.
    12-04-2012 07:01 AM
  4. PureEnergi's Avatar
    you can also set the background process limit. seems to work for me i have absolutely no problem lasting the day and i am a heavy web/email user. if i use it lightly it will easily last a day and a half.
    12-04-2012 07:38 AM
  5. hannsoft's Avatar
    Great tips, all, with the lone exception being the fact that we can't turn off LTE on the DNA..
    Sent from my HTC Droid DNA via Tapatalk 2
    12-04-2012 08:06 AM
  6. varucell's Avatar
    How can you do this. That sound like a great idea.
    12-04-2012 10:20 AM
  7. dsignori's Avatar
    I don't do ANY of that, and suffer no hardships.
    12-04-2012 10:31 AM
  8. mclarryjr's Avatar
    Same here this is by far the best battery life I've seen from any Android device I've owned.
    Droid>Droid 3>Dinc>Thunderbolt>Gnex
    12-04-2012 10:42 AM
  9. phonenut's Avatar
    Here is my graph, any thoughts?
    my thoughts are that you're a very good diagram man
    12-04-2012 03:30 PM
  10. oscarnyc's Avatar
    you seem to have hit the tri-fecta of crappy battery life devices the the Dinc, T-bolt and Gnex. everything is relative.
    mclarryjr likes this.
    12-04-2012 03:55 PM
  11. scorpiodsu's Avatar
    Settings > Developer Options.
    12-04-2012 04:12 PM
  12. Danny Fernandez's Avatar
    What did you set your background proccess limit to? This didnt affect your phone negatively in anyway?
    12-04-2012 06:19 PM
  13. Sooks's Avatar
    Not sure if anyone has posted this yet, but the camera issue you are having is a "feature" of the phone, if you leave the camera app running then power off the screen or if you open the camera and not exit the application it will continue to run which is why you are seeing 22% of your battery going to camera. Its a "never miss a picture" feature. Try killing the camera with the app switcher ( not a task killer as they will actually cause more harm then good)
    mclarryjr and swenpro like this.
    12-05-2012 06:15 PM
  14. jrz5024's Avatar
    There is a stock widget you can use to disable data.
    12-05-2012 07:42 PM
  15. jrz5024's Avatar
    Great tips overall. I just wanted to note that while using a dark wallpaper on SAMOLED screens saves battery (as it turns off those individual black pixels), it won't do anything for LCD displays like on the DNA, which are backlit.
    12-05-2012 07:44 PM
  16. heath patrick's Avatar
    12 Hrs. on battery with 7 Hrs. of streaming music through Google play music,screen on for close to 2 hrs & Wifi on the entire time. Battery now at 37%
    12-05-2012 10:48 PM
  17. splmonster's Avatar
    Great points indeed! Only disagreement I have is some of the Google services. At least in my testing Gtalk, G+ and Google Now all used very little battery life across many of my devices. I also typically leave NFC on and it's completely dormant during non-use. Don't see it being a problem either.
    12-06-2012 12:56 AM
  18. hannsoft's Avatar
    http://i199.photobucket.com/albums/a...5-23-46-17.png
    Hey folks, how are all of you getting these screenshots??
    12-06-2012 06:06 AM
  19. heath patrick's Avatar
    Hold power and volume down buttons at the same time for a couple seconds.
    12-06-2012 06:58 AM
  20. PureEnergi's Avatar
    I set mine to 4. I set it to 4 on my gs3 also. Seems to work well. No adverse effects. Beats having 20-30 processes cooking in the background
    12-06-2012 08:03 AM
  21. aallison1882's Avatar
    The power button and volume down does not work for me. Only the power button and home screen button does.
    12-06-2012 09:47 AM
  22. mightyfacundo's Avatar
    It's good to see that some things about HTC don't change. This is how it is with the Thunderbolt. Some phones use the power button and home button to take a screen shot, while others, like mine, use the power button and volume down. I'd love to know why it's different.
    Sent from my ADR6400L using Android Central Forums
    12-06-2012 01:01 PM
  23. bellken's Avatar
    This is what works for me, too.
    12-06-2012 01:29 PM
  24. Sooks's Avatar
    You have to click the power and volume down at the same time and hold for 2 sec. However, this power and home is easy as well, thanks for sharing that!
    12-06-2012 02:51 PM
  25. dsignori's Avatar
    The both work, however the Power + Home Button method does not show the saved screenshot in the notification area, nor does it allow for quick sharing of it. The Power + Volume Down method does, so I prefer that way.
    12-06-2012 03:01 PM
84 1234
  1. How is the battery life on the skyrocket?
    By Lavitapostandroid in forum Samsung Galaxy S II Skyrocket
    Last Post: 06-19-2012, 02:13 AM
  2. Is the battery life really this bad?
    By joe_sun in forum Verizon Galaxy Nexus
    Last Post: 03-28-2012, 09:50 AM
  3. All this crying on the battery life on the first true 4G mobile
    By Chilly818 in forum Thunderbolt Accessories
    Last Post: 04-04-2011, 12:59 PM
  4. All this crying on the battery life on the first true 4G mobile
    By Chilly818 in forum Verizon HTC Thunderbolt
    Last Post: 04-04-2011, 11:13 AM
  5. What's the battery life on this?
    By sekser in forum Google / HTC Nexus One
    Last Post: 03-15-2010, 04:36 AM
