scorpiodsu
How can you do this. That sound like a great idea.
Settings > Developer Options.
Great tips, all, with the lone exception being the fact that we can't turn off LTE on the DNA..
Sent from my HTC Droid DNA via Tapatalk 2
i suffer no hardships doing this -
Battery Tips for Android
6. Don't use Live Wallpaper. Use dark wallpaper if possible.
1. Toggle off LTE, WIFI, GPS, BT, NFC, Hotspot. Toggle on as needed.
2. Display Brightness - Turn off Auto Brightness and Reduce Setting Bar to Minimum.
3. Sign out of Google Latitude, GTalk, G+, Google Now, and Messenger. Disable Location Reporting/History.
4. Beware of constantly syncing Apps and Bloatware like Facebook, Twitter, News, Non-Push Email, etc. Set Sync interval for every 1 hour or more.
5. Turn off keyboard haptic feedback.
7. Set Display Sleep Setting to 2 Minutes or Less.
8. Set WIFI to Always stay on during Sleep if you regularly use WIFI.
9. Turn off vibrate for Emails.
10. Be careful of using too many live widgets.
11. Sync Exchange Emails 30 Days or less.
12. Do NOT use a Task Killer App.
12 Hrs. on battery with 7 Hrs. of streaming music through Google play music,screen on for close to 2 hrs & Wifi on the entire time. Battery now at 37%
http://i199.photobucket.com/albums/aa185/heath223/Screenshot_2012-12-05-23-46-17.png
Hey folks, how are all of you getting these screenshots??
What did you set your background proccess limit to? This didnt affect your phone negatively in anyway?
Hold power and volume down buttons at the same time for a couple seconds.
The power button and volume down does not work for me. Only the power button and home screen button does.
You have to click the power and volume down at the same time and hold for 2 sec. However, this power and home is easy as well, thanks for sharing that!
My battery life continues to be great with the DNA for my normal day to day use. I rarely get to 60% after 12 hours off the charger. I did notice one thing today that does eat the battery pretty aggressively. I had to navigate to a destination today, and decided to use Google Maps for turn-by-turn. I navigated for less than a half hour and lost just over 10% of my battery. This is probably the only reason I need to leave my charging cable in the car anymore. With my old Thunderbolt (I know...I know...), the car charger got used daily.
