Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By ShamelessMT
    Default car mode
    Looking for an app that maybe keeps the screen on while driving instead of changing the screen time out. My droid x had a dock app .
  2. #2
    Default Re: car mode
    Fantastic app I've been using for about 2 years now.
    HmCody likes this.
  3. #3
    Just use the built in car app. If you type in"car" in your home screen search widget, enable local search,it will show. Can create an icon using a file explorer.
    Sent from my HTC6435LVW using Android Central Forums
    Thanked by 2:
  4. #4
    Quote Originally Posted by goathog02 View Post
    ... Can create an icon using a file explorer.
    Thanks. I got to the app, but couldn't create a shortcut. I have Astro file explorer installed, but can't create a shortcut to the Car app still. How do you do this?
    Default
    Not finding anything on phone for car.
  6. #6
    jf2go's Avatar
    Posts
    Global Posts
    83 Global Posts
    Quote Originally Posted by dsignori View Post
    Install QuickShortcutMaker from the Market. Run that App and search for 'Car' in applications. It will find the hidden Car App and create a shortcut for you on the Home Screen.
    Thanked by:
  7. #7
    Quote Originally Posted by jf2go View Post
    Thanks. This worked.
  8. #8
    Does anyone know if you can edit the car app? I would like to add different music apps to the dock.
  9. #9
    Any way to edit the defaults on the stock car app? Don't use Pandora, stock music player doesn't recognize Play cache, I prefer my own navigation app, etc.
  10. #10
    bespinct's Avatar
    Posts
    Global Posts
    444 Global Posts
    ROM
    Stock!
    I don't think the stock app is editable. Try Car Home from Google play.
    Steve
    Sent from my HTC6435LVW using Tapatalk 2
  11. #11
    If you have Tasker, you can also use that to create a widget of the Car app.
  1. 3700k render effect in car mode?
    By darthwhit in forum Android App Inventor
    Last Post: 09-09-2011, 10:39 AM
  2. From Droid to Sense.. CAR MODE?
    By rjpear in forum Verizon HTC Thunderbolt
    Last Post: 07-26-2011, 01:56 AM
  3. Car mode?
    By alpha752 in forum Motorola Droid 3
    Last Post: 07-18-2011, 03:16 PM
  4. Car mode problems.
    By ninefall in forum Verizon HTC Thunderbolt
    Last Post: 03-20-2011, 11:25 PM
  5. car mode deletion
    By jim in syracuse in forum Motorola Droid
    Last Post: 12-08-2010, 11:38 AM
