Results 1 to 7 of 7
    jrmarinojr's Avatar
    Posts
    ROM
    Stock
    Default Problem Syncing iTunes Playlists
    Coming from a TBolt where I would use Doubletwist to sync my music (even though the playlists were not synched on the Doubletwist app, they still synced in the default music player). With the DNA, Doubletwist does not even recognize my phone as being plugged in. How do you change the USB settings because I cannot find it anywhere (the USB settings from the drop down menu only gives options for mobile hotspot, internet connection mode, and bluetooth tethering). Also, tried using HTC Sync which synced my music but NOT the playlists. Did everything that the DNA User Guide said and still no luck. Any feedback is greatly appreciated!
  2. #2
    Default Re: Problem Syncing iTunes Playlists
    I'm having issues getting my laptop to recognize my note II consistently so I purchased the doubletwist air app and it worked flawlessly. Pulled everything out of iTunes just like I wanted and let me choose the sd storage.
    Using tapatalk with my note II
  3. #3
    I used Airtwist with Doubletwist for Wifi Syncing and it worked just fine. The USB sync worked OK too as I remember. Sorry. ...
    jrmarinojr's Avatar
    Posts
    ROM
    Stock
    Its nice to hear that airsync works, however i don't want to spend money on something that isn't really necessary. Has anyone out there had any luck syncing their phones the old fashion way using cords?
  5. #5
    As long as you have HTC Sync installed (latest) you should have the proper drivers (win xp/7/8), you may need to reboot
    Open windows explorer and look for the additional 'drives' the mount system mount a couple images,
    That would tell u if ur phone's connected and you can try to drag/drop a file to test it (any file will do), any app after that would be app issue,
  6. #6
    cjmac97's Avatar
    Posts
    Global Posts
    31 Global Posts
    Google Music works flawlessly with the option to stream or store locally
    jrmarinojr's Avatar
    Posts
    ROM
    Stock
    How do you change the USB settings because I cannot find it anywhere (the USB settings from the drop down menu only gives options for mobile hotspot, internet connection mode, and bluetooth tethering). I need to set it to Disk Drive Mode. I can see the phone in "My Computer" which means my PC recognizes it. If that is the case then why doesn't Doubletwist recognize it???
  1. Sync iTunes playlists with Google Music
    By Southrncomfortjm in forum Android 4.1 / 4.2 Jelly Bean
    Last Post: 11-18-2012, 05:26 PM
  2. Sync iTunes Playlists with XOOM (Mac)
    By jeffmorr in forum Motorola Xoom
    Last Post: 02-29-2012, 12:24 PM
  3. doubleTwist to sync iTunes anyone? Have a problem
    By Bnjf in forum General Help and How To
    Last Post: 10-13-2011, 06:11 PM
  4. Motorola Media Link syncing iTunes Playlist issue.
    By eyarea51 in forum Sprint Photon
    Last Post: 09-27-2011, 01:52 PM
  5. Finally - iTunes Playlist sync!!
    By mjszabo in forum Verizon Fascinate
    Last Post: 04-05-2011, 08:05 PM
