- 12-06-2012, 12:48 AM
Thread Author #1
Light Bleed onto display
Anyone else seeing the light from the capacitive buttons on the display? Nothing major, just noticed on videos or any dark screens the light seems to shine through a bit.
- 12-06-2012, 12:57 AM #2
- 12-06-2012, 01:17 AM
Thread Author #3
- 12-06-2012, 06:49 AM #4
Re: Light Bleed onto display
This is the first HTC I've had that doesn't bleed light from the bottom edge of the display.
Send from my DNAHTC Droid DNA Employee Edition 00960
HTC DNA
HTC Droid Incredible 4G - 12-06-2012, 11:49 AM #5
I am on DNA number 3 currently, and I finally got one with no light bleed. So if you notice it, exchange it because there are some with none.
- 12-06-2012, 12:48 PM #6
where exactly are/were you seeing light bleed?
After reading this thread I went into my office bathroom and set a black wallpaper.
I notice when you're holding the phone as if you are looking directly at the USB port, you do see 3 areas of light bleed from where the capacitive buttons are.
As far as the display goes, There is a TINY amount of light bleed when looking at a completely black wallpaper in a completely dark room.
all this really can't be replicated when viewing at my desk with office lights above my head.
Does your current device not have ANY light bleed at all? from the display to the outer area by the usb port?
If it's possible to not have any light bleed, I might just exchange mine for another one. - 12-06-2012, 02:47 PM #7
The light bleed was the entire bottom of the device from edge to edge NOT on the screen at all though. Current one has ZERO light leak, just be careful because dna 1 had bad light leak, 2 had even worse ..
Thanked by: - 12-06-2012, 03:02 PM #8
- 12-06-2012, 11:45 PM
Thread Author #9
What I'm saying is... During darker videos or movies or on darker screen you can see the light shine through onto the screen from the buttons. It's nothing major, but sort of an annoyance. I have not opened one DNA out of the box without the issue.
- 12-10-2012, 09:24 PM #10
- 12-11-2012, 08:25 PM
Thread Author #11
- 12-12-2012, 02:52 AM #12If I were never here, you would never know.
- 12-12-2012, 06:13 PM #13
- 12-17-2012, 01:27 PM #14
Light bleed/leak on bottom right corner of display?
By jkel777 in forum HTC One XReplies: 0Last Post: 06-26-2012, 07:38 PM -
Light bleed?
By varucell in forum ASUS EeePad TransformerReplies: 96Last Post: 08-01-2011, 08:48 PM -
light bleed bottom left corner
By Flyers1121 in forum Samsung Galaxy Tab 10-inchReplies: 6Last Post: 06-20-2011, 06:17 AM -
light leak onto screen
By logicalform in forum HTC EVO 4GReplies: 4Last Post: 06-13-2010, 06:47 PM -
Light leakage onto screen (not below buttons)
By emaddox84 in forum HTC EVO 4GReplies: 6Last Post: 06-07-2010, 10:54 AM
Reply
. Go to all lengths to test !!!
