Results 1 to 17 of 17
- 12-06-2012, 11:31 PM
Thread Author #1
GPS agreement box keeps popping up. Why?
I keep having the GPS agreement message box (the one that pops up when you select GPS under location settings) appear while I am using the phone to play games, browse internet or even read on kindle app and I have no idea what I am doing to cause it. Popped up at least once when I was not even touching the screen. Anyone got any ideas? Thanks for any input.
- 12-06-2012, 11:38 PM #2
Re: GPS agreement box keeps popping up. Why?
do you have all three location services checked?
- 12-06-2012, 11:51 PM
Thread Author #3
- 12-06-2012, 11:52 PM
Thread Author #4
- 12-06-2012, 11:56 PM #5
And it always will when apps need gps
Sent from my X-Band Modem... TY Genesis - 12-07-2012, 12:02 AM
Thread Author #6
But it happens when I play words with friends or other games, am reading this forum or news sites. None of the things I am doing requries gps and I have not accidentally hit an add when this happens that I can recall. I captured a bunch of screen shots of this happening and can see nothing requiring gps.
- 12-07-2012, 12:26 AM #7
then a backgroud app is using it. Maps, facebook, it could be anything.
- 12-07-2012, 12:28 AM
Thread Author #8
I went through all of the permissions for all of the apps I have been using when this has happened and none of them specify they use location services except for google/internet. On my Incredible I would accidentally hit the search key all the time and search would come up. This is similar, but do not know what I am doing to make the gps box appear.
- 12-07-2012, 12:31 AM #9
I cannot tell you what it is, but I can tell you the solution. Enable all three and it will stop
Sent from my X-Band Modem... TY Genesis - 12-07-2012, 12:40 AM
Thread Author #10
- 12-07-2012, 12:45 AM #11
No problems, wish I could help you narrow it down more but I have no idea what the frequency any app asks for the permissions. I just let them run full on.
Sent from my X-Band Modem... TY Genesis - 12-07-2012, 12:48 AM #12
I just looked at my phone and Google services uses location as well and that could be a few different apps...Google now (search) could be checking in as well
- 12-07-2012, 08:38 AM #13
There must be another answer, There is no reason to keep you GPS on, I only turn it on when Using maps/Nav and don't see any recurring prompts.
You'd want to keep it off as part of power management, no need to keep the GPS polling when your indoors. I keep vZ location services and Google checked only.
There is something definitely running that's prompting you, it isn't google + since i use it regularly . There are some apps I have To track Hikes etc, and they will prompt
but only when I start them. - 12-07-2012, 09:57 AM #14
This is not true actually, for the most part anyway. There is no real reason to keep GPS OFF honesty. Having it "on" only makes it available for apps when they need it. If you don't want apps using it, disable it within the apps or don't use those apps. Turning GPS off - in and of itself - saves no battery at all .. Apps actually USING GPS is what uses the battery ...
- 12-07-2012, 04:20 PM #15
- 12-08-2012, 10:15 AM #16
No need to be rude here. I don't think we are actually disagreeing. This isn't a battery life issue, and mine polls GPS indoors without issue or popups.
That said, none of this is helping the OP. He is asking why he keeps getting agreement popups. I haven't seen that, nor heard of that happening before, sorry. The only thing I can think of is to go in under "Settings", "Accounts and Sync", "Google" and check the "Search" and the "Location" areas to see what you have set. Also, other accounts may be trying to ascertain your location - ones not related to Google. - 12-08-2012, 10:53 AM
Thread Author #17
I disabled "location picker" and have not noticed the pop ups since. Prior to that I had turned off permissions for location in most apps without any difference. Not sure what location picker is, or if I need it, but if keeping it disabled works to stop the gps screen from showing up randomly, disabled it will likely stay. Does anyone think leaving this disabled will hurt funtionality of phone much?
Many thanks to all for the input.
"USB connected" keeps popping up when unplugged
By GalaxyNole in forum Verizon Fascinate Rooting, ROMs, and HacksReplies: 4Last Post: 02-23-2013, 09:25 AM -
Why does my Data Roam Guard keep popping up?
By nealoc187 in forum LG Optimus SReplies: 3Last Post: 07-03-2012, 08:04 PM -
why does my network screen keep popping up?
By debsdroid in forum Verizon HTC RezoundReplies: 4Last Post: 01-17-2012, 09:42 AM -
Same text message keeps popping up in the notifications?
By jonkim723 in forum Verizon Droid IncredibleReplies: 10Last Post: 05-31-2011, 12:09 AM -
Applications keep popping up in the background?!
By kelv1ntran in forum HTC HeroReplies: 1Last Post: 01-14-2010, 05:07 PM
Reply
