By now we all had a chance to really get in to the DNA ,what would you want addressed in the first update by HTC.
I thing volume may be one .
Separate volume of ring tone and notifcations
Sent from my HTC6435LVW using Tapatalk 2
That there is no "Quick Settings' on top pull down menu you like every other device has now? I mean yes I can hit the gear but really no buttons for data / gps / bluetooth or anything is just lazy.
What other phones have that feature besides Samsung phones?
It's a feature of 4.2,so I wouldn't be surprised to see it in the next update.
The 4 icons at the bottom? You can put whatever you want there, just drag and drop.Customize the lock screen targets. I don't need lock screen widgets (they're a bit clunky right now anyway) but would like to be able to change the shortcuts.
Widgetsoid has a terrific, fully customizable notification quick settings bar. Highly recommend.That there is no "Quick Settings' on top pull down menu you like every other device has now? I mean yes I can hit the gear but really no buttons for data / gps / bluetooth or anything is just lazy.
