Page 1 of 3 123 LastLast
Results 1 to 25 of 51
Like Tree6Likes
    ptm88's Avatar
    Posts
    Global Posts
    102 Global Posts
    Default Battery Life Issues, what are you guys running?
    I know we have a lot of battery life threads and I absolutely love this phone but mine is not getting good battery life. I'm an advanced android user, I know it well and I do know that some devices just have bugs which kill battery life. My last device (an S3) had great battery life, I replaced it when the GPS radio died on it and the new one was atrocious on battery life with the same settings so I know they can differ. I look on here and some of you guys are getting great battery life, my question is do you have google now and gps disabled to achieve this?
    Right now i'm getting 10 hours of battery life with moderate usage, minimum sync settings, gps and wifi on, screen running around 40% brightness. It doesn't seem right, should I return it and exchange for another device?
    Thanks
  2. #2
    jrz5024's Avatar
    Posts
    ROM
    ACS SyndicateROM Frozen
    Default Re: Battery Life Issues, what are you guys running?
    Quote Originally Posted by ptm88 View Post
    Thanks
    Doesn't seem right, I'd get a new one. I would consider myself a moderate user (texting throughout the day, a few phone calls, some web browsing / flipboard and maybe ~30min game playing) and I regularly get 15-20 hours on Wi-Fi.
    ptm88's Avatar
    Posts
    Global Posts
    102 Global Posts
    Yea thats what I figured I'll see what a new one would do, I'm not giving up on this that easy- this phone is too good!
    ptm88's Avatar
    Posts
    Global Posts
    102 Global Posts
    Got a new one and set it up, burned 3% first hour....that's pretty awesome!
    paulmike3 and bellken like this.
  5. #5
    There are many variables that go into battery consumption 10 hrs but it depends alot on your 4g/3g coverage (prob highest killer if your switching back and forth where you live). I'm not sure 10hrs would be returnable, but you can try.
  6. #6
    3% in your first hour of doing what exactly? Trying to compare other peoples results with my own...
    ptm88's Avatar
    Posts
    Global Posts
    102 Global Posts
    I put my apps on there, reset it and just did moderate usage, and it was noticeably much better than the last device. For the entire day today I did 3.7% with three phone calls for about an hour, streamed google music for 45 minutes and about 70 text messages and messed around on FB for 30 min probably. I don't know what was up with the last device except I think I got a bad battery. Its really great now....
  8. #8
    Default
    I bought one of those wireless chargers. I leave work fully charged every day. Put it on the charger on my desk instead of on a belt clip or in my pocket.
  9. #9
    Default
    Only burned 3.7% after doing all of that? I go through that without hardly touching the phone in an hour. I must have somethin wrong..
  10. Thread Author  Thread Author    #10
    ptm88's Avatar
    Posts
    Global Posts
    102 Global Posts
    Schwinn uncheck verizon location in the location settings, and also I only have the gmail syncing and other pop email every 15 minutes. I have location on and wifi on. All my twitter, Facebook, dropbox and every other account is set up as do not sync. When I open them they update so no reason to have that stuff running in the background. Try that you'll be amazed how much it helps it.
    Thanked by 2:
  11. #11
    thanks ptm, it seems like i have everything set up pretty close to what you said. my emails are at 15min, all my google and maps location stuff is off, however i didnt uncheck the verizon location because i didnt know what that may affect. i dont use facebook, dropbox, twitter etc. the only thing i use is instagram and that only updates when i open it anyway. my normal day is 9 hours of the phone laying in my toolbox not being used for anything besides some texting, and some messing around at night and i always end up below 40%. so a day with some moderate use would never happen, im thinking somethings up. going to stop at verizon tonight.
  12. #12
    All locations on, manual sync for everything, brightness at about 10%, wifi 90% of the time, and moderate usage. I drain about 20% battery per hour of screen time and 1% per hour of idle. For example, today my phones been off the charger for 9 hrs with 1 hour of screen time texting, navigation for a bit, and checking facebook, I'm at 71%. Does that seem normal?
  13. #13
    Quote Originally Posted by E_PEV View Post
    I had locations on, wifi 98% of the day, auto brightness, and screen on time was about 1 hour and that was from just checking battery and settings. After 11 total hours from a full charge, was down to 55%. Does that seem right?
    seems better than me, i had locations off, wifi off half the day, screen time probably about the same and auto brightness. 9.5 hours at 31%
  14. #14
    Quote Originally Posted by schwinn123 View Post
    Sorry, I just edited my post to a more general usage. Yours definitely seems bad though if thats a typical day.
  15. #15
    bespinct's Avatar
    Posts
    Global Posts
    443 Global Posts
    ROM
    Stock!
    I wish there was some way to identify what kind of use we really have as a comparison. I think I am moderate user with my phone off the charger at about 0630 and not back on until 2200 at the earliest. The battery is almost always above 10%. I'm starting to think that everyone's experience is so unique that comparisons don't really apply.
    Sent from my HTC6435LVW using Tapatalk 2
  16. #16
    Quote Originally Posted by bespinct View Post
    Very true so it's hard to know if your phone has a problem or not. I thought mine was draining fast based on these "comparisons" so I took into the Verizon store. The rep said that what I was getting is normal and had a someone from tech support tell me the same thing meaning no replacement for me. I wish it were easier to make comparisons so I could know for sure
  17. #17
    Just left the verizon store, was told the same thing. 12 hours of charge is standard. but i dont know what her standard meant, she wouldnt say. i wouldnt call my days standard and at 10.5 hours im at 25%. just seems kind of bad, the old iphone 4 wouldn't have drained down to 25% with muchhhhh more use. In fact i rarely saw under 50% ever. But this phone blows that phone away, so who knows.
  18. #18
    This exactly and I also came from an iPhone 4. I was told 12 hours for the DNA by the tech support. They even went as far as noting my account with the fact that the battery life is normal in case I tried somewhere else and I thought that was a bit ridiculous. It may be normal for my use and it may not be but if its draining significantly faster than what other people are saying, I have no problem calling Verizon and taking things higher
  19. Thread Author  Thread Author    #19
    ptm88's Avatar
    Posts
    Global Posts
    102 Global Posts
    Yea its weird if you go over to xda some guys are getting insane battery life, like over 20 hours and 5-6 hours on screen time. I'm running at 5% an hour with pretty heavy usage and around 3.5% an hour with moderate. At 5% an hour I would be around that 20 hour mark but thats about 3 hours of screen time not 5-6. I do think a lot of this has to do whether your using wifi or not to stay connected and how well your 4g signal is in your area. My 4g is ok about 100dbm at home and I work from home but it doesn't switch around searching for 3g, if it does that the battery life goes in the tank and thats with any phone. My results are in a controlled environment 80% of the time unless I leave, that makes a big difference ...
  20. #20
    5% an hour of screen time? Screen time + idle? Or just idle? I ask because I can get 3 hours of screen time easily before dying from a full charge. Is that what you're getting?
  21. #21
    YourMobileGuru's Avatar
    Formerly VZWRocks
    Posts
    Global Posts
    4,226 Global Posts
    ROM
    what's wrong with stock?
    Moderate usage 15 hrs today from full charge to 5% not doing anything special for battery conservation.
    Sent from my HTC6435LVW using Android Central Forums
    Android is all about Personal Choice: Droid RAZR HD, Droid DNA, SGSIII, SG Note 2, HTC One X+, Galaxy Nexus, Nexus4... Hating is so Apple... we're better than that!
    Correcting Some of the Shared Everything Misinformation * My Phone Collection
    PSA - Verizon Galaxy Nexus Signal Strength Comparison
  22. Thread Author  Thread Author    #22
    ptm88's Avatar
    Posts
    Global Posts
    102 Global Posts
    Screen time plus idle, yea thats pretty good, your good from that angle. I can't get 5 or 6 hours of screen time. Today I averaged 3:30 screen time and I have 18% left. I unplugged at 7 this morning so I'm at 17 hours right now. But like I was saying its hard for all of us to compare because environment matters so much to battery life, I only left my house for an hour today so I stayed in my signal and was on good wifi all day. I imagine if I was gone all day, utilizing just LTE I wouldn't be getting such great life - maybe 25% less. Friday I will be flying to maine and home that night - I'm curious how it will do then. I'll definitely let you know. Either way I think 12-14 hours is good for these devices, especially how powerful they are. Anything less than 12 would really suck..
  23. #23
    Definition of "heavy", "moderate", and "light" vary as well. Since were getting similar overall screen time and overall daily time but very different hourly drain, I would say our definition of "heavy use" in an hour is different haha. I'm curious to see what kind of battery life you'll get as well. Your previous DNA had a battery problem then?
  24. Thread Author  Thread Author    #24
    ptm88's Avatar
    Posts
    Global Posts
    102 Global Posts
    Yea it was bad, I couldn't even get eight hours and the battery would charge completely from zeroin less than an hour. I think it had damaged cells or something. I took it back to Verizon and told them the bluetooth would disconnect at times, thats how I got new one with no hassle...I lied
  25. #25
    Getting a full day easily
    Attached Thumbnails Attached Thumbnails Battery Life Issues, what are you guys running?-uploadfromtaptalk1355382575747.jpg
  1. What are you guys doing for spare batteries?
    By drewsg in forum Epic 4G Touch Accessories
    Last Post: 08-03-2012, 01:32 PM
  2. What are you guys seeing for battery life?
    By potam in forum Verizon Galaxy Nexus
    Last Post: 12-14-2011, 11:19 PM
  3. What are you guys using for keyboards?
    By Jesse Potter in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 09-25-2011, 01:08 AM
  4. Plans, what are you guys paying per month...
    By biggamer3 in forum Sprint
    Last Post: 02-13-2011, 07:16 PM
  5. What are you guys doing for spare batteries?
    By in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 12-31-1969, 07:00 PM
