Results 1 to 4 of 4
    Default Proximity Sensor Sensitivity
    Has anyone else had an issue with the proximity sensor being oversensitive? If I'm in a call, I normally hold the phone in my left hand. If I unlock the screen then try to do anything with my right hand, the screen goes black. The proximity sensor seems so sensitive that just a finger 3-4 inches above the top-right quadrant of the phone will set it off. I haven't had this problem with other phones; is it just me, or are others having this issue too?
  2. #2
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    Carrier
    Something JB
    Default Re: Proximity Sensor Sensitivity
    I have it with the SGS3, annoyed me for awhile but changed how I do things just a bit...
  3. #3
    ncbryan's Avatar
    Posts
    Global Posts
    341 Global Posts
    I just picked up my DNA this morning and still getting used to the change from Samsung to HTC. One thing I have noticed during calls is the screen stays on and does not go dim. My cheek has activated the screen several times during calls and once somehow started a video in the middle of my call. How do I check the proximity sensor to see if there is a setting to turn it on or off? Can't find it?
    Bryan
  4. #4
    I read somewhere (and I'm trying to find out where) that if you have a screen protector that does not have an opening on for the P Sensor that it will interfere with its operation. It's difficult to find a screen protector which definitely shows having the cutout! Perhaps that is the issue?
  1. Proximity sensor issue?
    By Deofol in forum Motorola Droid
    Last Post: 03-16-2011, 01:25 PM
  2. Ending calls with Froyo (Proximity sensor)
    By cwhite12200 in forum Motorola Droid
    Last Post: 08-12-2010, 03:06 AM
  3. Disable proximity sensor while on a bluetooth call
    By WillJitsu in forum HTC EVO 4G
    Last Post: 06-20-2010, 05:08 PM
  4. Proximity sensor whoes
    By WAM in forum Motorola Droid
    Last Post: 05-25-2010, 08:19 PM
  5. Proximity sensor question
    By eKennedy#AC in forum Motorola Droid
    Last Post: 12-03-2009, 08:35 PM
