Storage solution, Kingston 32gb Wi-Drive $50 on Amazon
For those worried about storage capacity, this looks to be a pretty good solution. D/L the android app, and you don't need to worry about connecting memory sticks via usb cable.
[Only registered and activated users can see links. Click Here To Register...]
Re: Storage solution, Kingston 32gb Wi-Drive $50 on Amazon
I actually have the 64GB wi drive that I've been using with my Nexus 7. It works great. I store all my movies, files, and music on it. I downloaded the app for the dna yesterday and it works just fine.
If you want something more pocket-friendly, but almost 3x more expensive, there's this: [Only registered and activated users can see links. Click Here To Register...]
you stick any SD card in it, and it makes it wireless.
I'd jump on one if the Wi-Drive or the Go-Flex if they were smaller, or the AirStash if it was considerably cheaper. I like to travel light, but these are definitely great options.
