DEAL OF THE DAY: Save 60% on the LLOYD Flex Case for Samsung Galaxy S3!
Results 1 to 4 of 4
    a62335's Avatar
    Posts
    Global Posts
    109 Global Posts
    Default Storage solution, Kingston 32gb Wi-Drive $50 on Amazon
    For those worried about storage capacity, this looks to be a pretty good solution. D/L the android app, and you don't need to worry about connecting memory sticks via usb cable.
    Amazon.com: Kingston Wi-Drive 32 GB USB 2.0 Pocket-sized Portable Storage WID/32GBZ: Electronics
    HTC Droid DNA Employee Edition 00960
    HTC DNA
    HTC Droid Incredible 4G
  2. #2
    Default Re: Storage solution, Kingston 32gb Wi-Drive $50 on Amazon
    I actually have the 64GB wi drive that I've been using with my Nexus 7. It works great. I store all my movies, files, and music on it. I downloaded the app for the dna yesterday and it works just fine.
  3. #3
    If you want something more pocket-friendly, but almost 3x more expensive, there's this: Amazon.com: Maxell AirStash Expandable Capacity Wireless Flash Drive A02 (Included Starter 8GB Class 10 SDHC Card): Electronics
    you stick any SD card in it, and it makes it wireless.
    I'd jump on one if the Wi-Drive or the Go-Flex if they were smaller, or the AirStash if it was considerably cheaper. I like to travel light, but these are definitely great options.
  4. #4
    Good to know. Thanks!
    Dropbox | http://my.cur.lv/dropbox
    GoDaddy | 20% off with WOWBITCOIN code
    Earn BTC | https://coinurl.com/index.php?ref=socialsales
  1. Wi-Drive As A Storage Option for N7?
    By dougf4 in forum Google Nexus 7 Tablet
    Last Post: 07-04-2012, 09:47 AM
  2. Kingston 32GB MicroSD listed in stock at Newegg
    By capitaltpt in forum Epic 4G Accessories
    Last Post: 10-29-2010, 07:10 PM
  3. Having issues with a Kingston 32gb memory card
    By pat_the_cat in forum Google / HTC Nexus One
    Last Post: 10-10-2010, 09:25 PM
  4. [FIX] Reboots and random wi-fi drops on CM6.x, Ruby 1.1.1, ShadowROM...
    By crondable in forum Incredible Rooting, ROMs, and Hacks
    Last Post: 10-04-2010, 09:35 AM
  5. Replies: 1
    Last Post: 07-08-2010, 07:10 PM
