Results 1 to 11 of 11
    Default GS III wall charger with DNA
    I'm happily getting my GS III replaced with a "certified like new" DNA from Verizon (8 gs iii replacements later). The lady I talked to said I should just keep the galaxy charger and use it for the DNA rather than them sending me an accessory pack for the DNA. Should this be fine? I know it won't damage the phone or anything, but will it charge to the fullest potential or should I give them another call?
    Sent from my SCH-I535 using Tapatalk 2
  2. #2
    8100User's Avatar
    Posts
    Global Posts
    109 Global Posts
    Default Re: GS III walk charger with DNA
    Personally, I think you should pick up an inductive charger, and just use that!
    One of the nicest features of the DNA is build in inductive charging! No need to spend money on an inductive replacement back... just pick up a charging pad, and now, whenever you need to charge your DNA, you just lay it down on the pad, and it starts charging!
    Why bother plugging/unplugging a usb cable, unless money is really an issue.
  3. #3
    But if you don't want to do that, then yes the charger from your gs3 will charge your DNA just fine. If you want an extra charger for work or something then give them a call and ask for it but your old charger will work on it
    Thanked by:
  4. #4
    I have charged my phone with a charger from a Galaxy Note, as long as it is a 1 amp charger, which, it will likely be, it should be fine.
    Thanked by:
    Default Re: GS III wall charger with DNA
    Quote Originally Posted by shel View Post
    I had an inductive charger for an HP TouchPad and it was definitely worth the $35 I had paid, but $70 for a mat is a little out of my price range atm.
    Thanks for the reassurance, guys! I my give them a call and just ask them to send me a charger anyway.
  6. #6
    bassjo's Avatar
    Posts
    ROM
    Stock
    Quote Originally Posted by Infinite Jest View Post
    I got the LG charging pad, it didn't cost $70, more like $49 and if you have a discount through work, mine is 25%, you'll only pay approx. $30+/- a few bucks.
  7. #7
    Who?'s Avatar
    Posts
    Global Posts
    400 Global Posts
    You went through 8 gs3s? At what point do you begin thinking that the problem isn't with the phone?
  8. Thread Author  Thread Author    #8
    Quote Originally Posted by bassjo View Post
    Where did you get yours?
    Quote Originally Posted by whatwhat View Post
    Trust me, I examined both myself and the phone and determined it was the phone. I've never been more disappointed with a piece of hardware. I was going to stick with the one I have now despite the fact that reverse burn in has already occurred where the notification bar is (came like that from verizon) and a borderline nonfunctional gps antenna, but the sleep button fell off, so I just said enough is enough.
  9. #9
    bassjo's Avatar
    Posts
    ROM
    Stock
    I got it at a VZW corporate store before Christmas but I can't locate it on their website.
  10. #10
    You can also get a Nokia charging pad for about $39 @ Verizon. If you can't find one, try a local At&t store.. They always have them in stock but, they'll be a couple $ more. You may also get a sales rep, who will argue with you that it'll not work. Apparently they believe only the Nokia windows phone comes with built in inductive charging.
  11. #11
    Quote Originally Posted by doogie1 View Post
    I picked up mine from a AT&T store and they where shocked that I didn't have a Nokia phone.
  1. Car charger with long cord
    By Tar Heel in forum EVO Accessories
    Last Post: 04-13-2011, 04:58 PM
  2. Safe to use other microUSB phone chargers with Bolt?
    By Bwangster12 in forum Verizon HTC Thunderbolt
    Last Post: 03-25-2011, 08:58 AM
  3. Wtb: Rocketfish micro usb charger with serial code rf-mcb90
    By Matty Mo in forum Sold / Archived Marketplace Threads
    Last Post: 02-10-2011, 11:42 PM
  4. Stock charger with 1800mah battery?
    By jerethi in forum Verizon Droid Incredible
    Last Post: 01-29-2011, 08:34 PM
  5. Need a Car Charger With A Right Angle Plug
    By kg6bki in forum Epic 4G Accessories
    Last Post: 12-09-2010, 03:23 PM
