"I understand you are wanting the drivers for your HTC Droid DNA. I will be more than happy to further assist you.
Austin, If you are only connecting in disk drive mode to copy pictures we can just toggle an option on your phone so the PC won't ask for a driver. From your home screen navigate to your settings>developer options and ensure usb debugging is unchecked. Then hold down your power button and select restart. When the phone boots back up just plug it into the computer and select disk drive as your connection type. Your images will be in the DCIM>100Media folder on the drive that appears on your computer. If you would like to sync calendar and contacts, among other data, between your phone and PC you can use HTC Sync, which includes the driver, from: (
https://forums.androidcentral.com/e...F%2Fwww.htc.com%2Fus%2Fhelp%2F&token=XtA4l0kG ). You don?t have to select a phone or region, just scroll down and look to the right for ?HTC Sync Manager? to download the application. If you continue to have trouble, please let me know. I hope you are having a wonderful weekend!
Thank you for taking the time to contact HTC. I hope you are having a great day! If you ever have any other questions or concerns in the future, always feel free to contact us via e-mail or phone. Our phone support department can be reached at 1-866-449-8358 between the hours of 6 A.M. and 1 A.M. EST, seven days a week. Also your voice is the most important part of HTC."
Email 2
Thanks for your reply!
It absolutely does work the same way. To transfer your music to your DNA, simply plug the device to your computer via the USB cable that came with the device. Once you have done this, select Disk Drive mode. When you have done this, you will be able to access your device as if it were a removable disk drive and you can simply drag-and-drop your media onto your device. When you have finished, unmount your device and open the Music application -- the music you placed on your device should be recognized!"
Sent from my HTC6435LVW using Android Central Forums
